Someone suggested turning the temperature control to the off position-I did that and the compressor stopped. Howevever at any other setting the compressor does not stop and continues to run non-stop. One side of the upright freezer becomes extremely hot, to the point it is uncomfortable to touch. Like I said before, I just charged it and I am concerned if by using too much refrigerant, that this may be the reason it is getting too hot and not going through it's off and on cycles. Any suggestions?
