| » No water in ice maker |
Quote:
Is your problem- water getting on the floor of the kitchen with water leaking out the door of the freezer. |
But there is not water going to the ice maker??
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear |
When I switched wires on the water valve and hit the water dispenser no water came out at the ice maker, but a couple minutes later water came out the water dispenser. I think the water valve to the ice maker isn't working and the water valve may be bad. Does that make sense? How can this be checked? Thanks
Were the wires still swapped when the water came out of the dispenser. If so it shows the ice maker is calling for water. You have already checked the valve and the ice maker side of it is bad. You can now replace it.
| Display Modes | |
| New ice maker installed but no water running to ice maker | corona32guiness | Refrigerator & Freezer Repair | 0 | 01-06-2010 05:14 PM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:27 AM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:20 AM |
| water not getting to hose from pump but water dispencer works not ice maker | sharbrat | Refrigerator & Freezer Repair | 0 | 07-29-2009 10:38 AM |
| Replaced Ice Maker and noid and still no water to ice maker | darrewhite | Refrigerator & Freezer Repair | 0 | 05-17-2009 06:34 AM |
