OK, I have tracked down the problem to the water coming out of the intake water valve. I have replace the water valve with a brand new one and there is still very little water coming out of the valve when activated. Water lines are clear. Pressure is great entering the valve. New valve acting the same as the old one. I am thinking electrical issue. maybe not enough current to the valve to open it all the way. What part should I look at replacing if this is the cause. Mother board? Not sure. Please advise ASAP
