Hi I just picked up an older Amana side by side fridge it has the ice maker and water dispenser on front, I finally got the ice maker up and going but I was going to test the water dispenser and it started spraying all over my feet I looked down and their is the line not connected to anything and I don't see where to connect it any suggestions?
Originally Posted by: jk115470 Hi I just picked up an older Amana side by side fridge it has the ice maker and water dispenser on front, I finally got the ice maker up and going but I was going to test the water dispenser and it started spraying all over my feet I looked down and their is the line not connected to anything and I don't see where to connect it any suggestions? JK, If you remove the kickplate grille, on the front bottom of the fridge, you should be able to see the 5/16" plastic water tube, that exits the freezer door, and passes through the lower hinge assembly. There should be another matching tube mounted to the bottom of the freezer floor by a spring loaded clip. and there should be a "double male" tube connector that attaches the two tubes. Someone probably pulled them apart when moving the unit. Good Luck, :) :) :)
