door gasket was hot i cleaned underneath and spun the fan motor it started ran for a couple days with the gasket cooling down now gasket was hot a gain took fan cover off started it ran then shut off but not sure its starting on its own :(
I would replace the fan. Since you had to give it a nudge the first time it is no longer reliable. |
THIS FORUM IS DEAD!!!!!!! |
