Discuss
Condensation/water inside refrigator
 in
Refrigerator & Freezer Repair
Water pools inside of refrigerator. Have cleaned bottom section where coils located. Took out drain pan was dry. Unplugged refrigerator/freezer,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Condensation/water inside refrigator
  #1 (permalink)
Old 07-12-2011, 08:29 PM
Junior Member
LJ Franklin is on a distinguished road
Default Condensation/water inside refrigator
Model Number: 79182990   Brand: Kenmore   Age: More than 10 years
Unplugged refrigerator/freezer, let defrost. Removed bottom floor of freezer had a block of ice. Used hair dryer to defrost ice and area near back wall.
Still water collects inside of refrigerator.
Related Models
Kenmore 7919338911 ELECTRIC RANGE
Kenmore 7919338913 ELECTRIC RANGE
Kenmore 7919338981 ELECTRIC RANGE
Kenmore 7919338983 ELECTRIC RANGE
Kenmore 79531002700 REFRIGERATOR
Kenmore 79531006700 REFRIGERATOR
Kenmore 79539113600 SIDE-BY-SIDE
Kenmore 79551012010 REFRIGERATOR
Kenmore 79551012011 REFRIGERATOR
Kenmore 79551012012 REFRIGERATOR
Kenmore 79551013010 REFRIGERATOR
Kenmore 79551013011 REFRIGERATOR
Kenmore 79551013012 REFRIGERATOR
Kenmore 79551014010 REFRIGERATOR
Kenmore 79551014011 REFRIGERATOR
Kenmore 79551014012 REFRIGERATOR
Kenmore 79551016010 REFRIGERATOR
Kenmore 79551016011 REFRIGERATOR
Kenmore 79551016012 REFRIGERATOR
Kenmore 79551019010 REFRIGERATOR
Kenmore 79551019011 REFRIGERATOR
Kenmore 79551019012 REFRIGERATOR
Kenmore 79551022010 REFRIGERATOR
Kenmore 79551022011 REFRIGERATOR
Kenmore 79551022012 REFRIGERATOR
Kenmore 79551023010 REFRIGERATOR
Kenmore 79551023011 REFRIGERATOR
Kenmore 79551023012 REFRIGERATOR
Kenmore 79551024010 REFRIGERATOR
Kenmore 79551024011 REFRIGERATOR
Kenmore 79551024012 REFRIGERATOR
Kenmore 79551026010 REFRIGERATOR
Kenmore 79551026011 REFRIGERATOR
Kenmore 79551026012 REFRIGERATOR
Kenmore 79551029010 REFRIGERATOR
Kenmore 79551029011 REFRIGERATOR
Kenmore 79551029012 REFRIGERATOR
Kenmore 79551032010 REFRIGERATOR
Kenmore 79551032011 REFRIGERATOR
Kenmore 79551033010 REFRIGERATOR
Kenmore 79551033011 REFRIGERATOR
Kenmore 79551034010 REFRIGERATOR
Kenmore 79551034011 REFRIGERATOR
Kenmore 79551036010 REFRIGERATOR
Kenmore 79551036011 REFRIGERATOR
Kenmore 79551039010 REFRIGERATOR
Kenmore 79551039011 REFRIGERATOR
Kenmore 79551072010 REFRIGERATOR
Kenmore 79551072011 REFRIGERATOR
Kenmore 79551073010 REFRIGERATOR
Kenmore 79551073011 REFRIGERATOR
Kenmore 79551074010 REFRIGERATOR
Kenmore 79551074011 REFRIGERATOR
Kenmore 79551076010 REFRIGERATOR
Kenmore 79551076011 REFRIGERATOR
Kenmore 79551079010 REFRIGERATOR
Kenmore 79551079011 REFRIGERATOR
Kenmore 79551082010 REFRIGERATOR
Kenmore 79551082011 REFRIGERATOR
Kenmore 79551083010 REFRIGERATOR
Kenmore 79551083011 REFRIGERATOR
Kenmore 79551086010 REFRIGERATOR
Kenmore 79551086011 REFRIGERATOR
Kenmore 79551089010 REFRIGERATOR
Kenmore 79551089011 REFRIGERATOR
Kenmore 79551092010 REFRIGERATOR
Kenmore 79551092011 REFRIGERATOR
Kenmore 79551093010 REFRIGERATOR
Kenmore 79551093011 REFRIGERATOR
Kenmore 79551099010 REFRIGERATOR
Kenmore 79551099011 REFRIGERATOR
Kenmore 79551312010 REFRIGERATOR
Kenmore 79551312011 REFRIGERATOR
Kenmore 79551312012 REFRIGERATOR
Kenmore 79551313010 REFRIGERATOR
Kenmore 79551313011 REFRIGERATOR
Kenmore 79551313012 REFRIGERATOR
Kenmore 79551314010 REFRIGERATOR
Kenmore 79551314011 REFRIGERATOR
Kenmore 79551314012 REFRIGERATOR
Kenmore 79551316010 REFRIGERATOR
Kenmore 79551316011 REFRIGERATOR
Kenmore 79551316012 REFRIGERATOR
Kenmore 79551319010 REFRIGERATOR
Kenmore 79551319011 REFRIGERATOR
Kenmore 79551319012 REFRIGERATOR
Kenmore 79551322010 REFRIGERATOR
Kenmore 79551322011 REFRIGERATOR
Kenmore 79551322012 REFRIGERATOR
Kenmore 79551323010 REFRIGERATOR
Kenmore 79551323011 REFRIGERATOR
Kenmore 79551326010 REFRIGERATOR
Kenmore 79551326011 REFRIGERATOR
Kenmore 79551329010 REFRIGERATOR
Kenmore 79551329011 REFRIGERATOR
Kenmore 79551329012 REFRIGERATOR
Kenmore 79551372010 REFRIGERATOR
Kenmore 79551373010 REFRIGERATOR
Kenmore 79551374010 REFRIGERATOR
Kenmore 79551376010 REFRIGERATOR
Kenmore 79551379010 REFRIGERATOR
Kenmore 79558812900 REFRIGERATOR
Kenmore 79558813900 REFRIGERATOR
Kenmore 79558814900 REFRIGERATOR
Kenmore 79558814901 REFRIGERATOR
Kenmore 79558816900 REFRIGERATOR
Kenmore 79558819900 REFRIGERATOR
Kenmore 79558819901 REFRIGERATOR
Kenmore 79558822900 REFRIGERATOR
Kenmore 79558823900 REFRIGERATOR
Kenmore 79558826900 REFRIGERATOR
Kenmore 79558829900 REFRIGERATOR
Kenmore 79565002400 REFRIGERATOR
Kenmore 79565002401 BOTTOM-MOUNT
Kenmore 79565002402 BOTTOM-MOUNT REFRIGERATOR
Kenmore 79565004400 REFRIGERATOR
Kenmore 79565004401 BOTTOM-MOUNT
Kenmore 79565004402 REFRIGERATOR
Kenmore 79565009400 REFRIGERATOR
Kenmore 79565009401 BOTTOM-MOUNT
  #2 (permalink)
Old 02-21-2012, 08:47 PM
Junior Member
trlyka is on a distinguished road
Default
If your freezer is like mine......I had this happen a few times in a row. What I found was the freezer fans were being blocked with too many food items. It wasn't breathing properly, so ice builds up and blocks the drainage hole in the back of the freezer. This usually happens around the holidays when there is more food then usual, so keep items clear of that area of the freezer. At lease a couple inches from it.
Anyway, once you remove the freezers bottom pan (you don't even have to defrost for this if you don't want to), there is a metal strip along the back of the freezer. To the right of the middle in the metal strip is a small hole that is the drain tube. Usually, if you find ice build up under the pan, there is also usually ice build up on the metal part too and the hole is being covered and frozen over. This causes the condensation that would typically go into the pan under the fridge, to go into the fridge instead. It goes through the opening in the top back of the fridge. Sometimes the condensation pools under the veg bins, or goes onto the shelves. When you remove the bottom pan in the freezer, remove all the ice and expose the metal strip. Take a baster and apply hot water over the hole. Use a dish towel to soak up the water as you will be doing this quite a few (30-50) times until you see water in the catch pan under the fridge. once you see water going through, then add a few more squirts of hot water for good measure. This worked for me. Hopefully it works for you too.
Good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water is on inside of tub when tub is turned off mark wlodarczak Dishwasher Repair 0 09-08-2010 12:07 PM
GE Refrigator dispensing water beneath frig kiowagator Refrigerator & Freezer Repair 0 02-06-2010 12:19 PM
Water Condensation on Top of Door repairman999 Dishwasher Repair 0 11-24-2008 08:13 AM
Water Leak In Refrigator mark38842 Refrigerator & Freezer Repair 3 08-04-2008 02:38 PM
water inside refrigerator edbeck Refrigerator & Freezer Repair 1 09-25-2007 10:13 AM
