OK, been lurking on here, and following some suggestions on the posts, and still no luck,,, fridge stopped cooling well, and checked out the freezer coils,, the top part was frozen, thowed it out, and replaced the defrost adaptor control as noted in some posts...
Did not help, now fridge is even warmer,,, both fans work,, and when plugged in you can hear compressor running, it does get warm. I pulled the capacitor and checked the omhs on it, it did not show anything, I pulled the starter control and it did NOT rattle, but got a "generic" one from a repair center, and hooked it up... it still starts up, but does not cool, both inside fan in freezer and fan below are running, no frost showing on any coils...
The compressor seems to run, I ran the ohms check for continuity on the compressor and it showed it was OK according to some threads.
I can change the temp control and it will shut off the compressor, but netiher side gets cool and blows warm air now..
what are the other options, I am tired of throwing parts on this, but need it to run..
another thing to note, my dishwasher (also maytag) quit working just a week before, could this have been a power surge from storms?
any other ideas?
thanks
