Discuss
freezer fine/fridge warm
 in
Refrigerator & Freezer Repair
Hello MFG NO# P1125507WL Fridge up, Freezer down Freezer is running fine, fridge warm as stated. I removed the freezer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer fine/fridge warm
  #1 (permalink)
Old 07-10-2011, 11:01 AM
Junior Member
jnrkara is on a distinguished road
Default freezer fine/fridge warm
Model Number: BZ20QL   Brand: Amana   Age: More than 10 years
Hello
I removed the freezer back panel and there is slight ice build up, I feel the fan inside freezer and I feel a "humming/buzzing". If I spin the fan blades manually the motor tries to take over but seems not to have the power to keep it running.
Am I looking at a faulty motor? I looked up the Amana model in parts and did not see a motor for the circulating to the fridge.
No ice build up on the backside of fridge, coils are clean and fan underneath running fine.
Thank You
Rick
Ads By Google
Related Models
Amana BZ20QL Ref - Bottom Mounts
Amana BZ20QW Ref - Bottom Mounts
Amana BZ20R Ref - Bottom Mounts
Amana BZ20RE Ref - Bottom Mounts
Amana BZ20RG Ref - Bottom Mounts
Amana BZ20RL Ref - Bottom Mounts
Amana BZ20RW Ref - Bottom Mounts
Amana BZ22QE Ref - Bottom Mounts
Amana BZ22QL Ref - Bottom Mounts
Amana BZ22QW Ref - Bottom Mounts
Amana BZ22R3E Ref - Bottom Mounts
Amana BZ22R3L Ref - Bottom Mounts
Amana BZ22R3W Ref - Bottom Mounts
Amana BZ22R5L Ref - Bottom Mounts
Amana BZ22R5W Ref - Bottom Mounts
Amana BZ22RE Ref - Bottom Mounts
Amana BZ22RL Ref - Bottom Mounts
Amana BZ22RW Ref - Bottom Mounts
Jenn-Air C Surface Unit - Ddraft Ele
Amana C-11 Freezer - Chest
Amana C-15 Freezer - Chest
Amana C-19 Freezer - Chest
Amana C-28 Freezer - Chest
Hardwick C-413 Surface Unit - Gas
Hardwick C-414 Surface Unit - Gas
Hardwick C-423 Surface Unit - Gas
Hardwick C-424 Surface Unit - Gas
Hardwick C-433 Surface Unit - Gas
Hardwick C-434 Surface Unit - Gas
Hardwick C-443 Surface Unit - Gas
Hardwick C-444 Surface Unit - Gas
Jenn-Air C100 Surface Unit - Ddraft Ele
Amana C100DW Freezer - Chest
Amana C100FW Freezer - Chest
Jenn-Air C101 Surface Unit - Ddraft Ele
Jenn-Air C101-C Surface Unit - Ddraft Ele
Jenn-Air C101-J Surface Unit - Ddraft Ele
Amana C101DW Freezer - Chest
Amana C101FW Freezer - Chest
Jenn-Air C102 Surface Unit - Ddraft Ele
Amana C102B Room Air Conditioner
Jenn-Air C106 Surface Unit - Ddraft Ele
Jenn-Air C106-C Surface Unit - Ddraft Ele
Hoover C1065--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1067--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1069--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1085--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1091--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1099--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Maytag C10AALWH Freezer - Chest
Amana C10B Freezer - Chest
Amana C10B-2 Freezer - Chest
Amana C10B-A Freezer - Chest
Amana C10B-AG Freezer - Chest
Amana C10B-C Freezer - Chest
Amana C10B-G Freezer - Chest
Amana C10B-L Freezer - Chest
Amana C10B1 Freezer - Chest
Amana C10B3W Freezer - Chest
Maytag C10D  Freezer - Chest
Maytag C10J  Freezer - Chest
Amana C11 Freezer - Chest
Hoover C1111--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1119--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1119080 Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1121--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1123--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover C1125--- Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Jenn-Air C116 Surface Unit - Ddraft Ele
Jenn-Air C116-C Surface Unit - Ddraft Ele
Amana C11B Freezer - Chest
Amana C11B-A Freezer - Chest
Amana C11B-C Freezer - Chest
Amana C11B-G Freezer - Chest
Amana C11B-L Freezer - Chest
Amana C11F Freezer - Chest
Amana C11F-A Freezer - Chest
  #2 (permalink)
Old 07-10-2011, 06:16 PM
Junior Member
cpak007 is on a distinguished road
Default try this way
There is a door switch that you can hold it down with door open to check fan is working or not, it should be on with in a few second, also you can check the power to motor with Volt meter.
Quote:
Originally Posted by jnrkara View Post
Hello
Manufacturer NO# P1125507WL Fridge up, Freezer down
Thank You
Rick
  #3 (permalink)
Old 07-10-2011, 06:31 PM
Junior Member
Default
Quote:
Thank you cpak....
As it turns out, I was on the phone with Judd trying to order the new motor (which isn't listed in the parts here). I removed the motor and took emery cloth to the motor shaft cleaning build up, put some high temp grease on it and reassembled. The motor now runs like new.
I would purchase a new motor but its cost is $110.00. I will watch the the fridge and when the motor dies completely I will buy a new one. BTW the fridge in question is my man cave beer cooler only !
Thank you for your prompt reply!
Rick
  #4 (permalink)
Old 07-11-2011, 02:17 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Carefully compare the AP4503254 motor to your old one, should fit.
__________________
  #5 (permalink)
Old 07-11-2011, 04:19 AM
Junior Member
Default
Quote:
Thank you richappy. That appears to be the same except with a longer shaft that would need to be cut down. At $20.00 I am on that!
again thank you
Rick
  #6 (permalink)
Old 07-11-2011, 04:29 AM
Senior Expert
APP Volunteer
Default
The shaft has ridges in it that greatly facilitate break off. Just use two pliers and break off the shaft down to the length needed. Also, this is a universal motor. Put on the fan blade and plug in the motor. If the blade turns the wrong way, you will need to take apart the motor and reverse it. Be careful to put back all the thrust washers.
This is a much more reliable motor than your old one at a fraction of the cost!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge warm freezer is fine stratblast Refrigerator & Freezer Repair 9 07-06-2012 02:22 AM
fridge is warm freezer is fine harry06 Refrigerator & Freezer Repair 1 07-06-2011 02:31 AM
GE fridge is warm freezer is fine stucake Refrigerator & Freezer Repair 0 12-05-2010 06:48 PM
Fridge Warm, Freezer Fine flyinfish Refrigerator & Freezer Repair 1 07-08-2009 03:23 PM
Fridge is warm, freezer is fine! AMYTORRES5946 Refrigerator & Freezer Repair 0 06-15-2009 06:24 PM
