I have a brand new fridge, after the doors and drawer were removed to get through a doorway, it was powered up without the doors and drawer reinstalled to see if it had power. I'm not sure why. Then I think they tried to attach the doors and drawer without powering it down, they shouldn't have powered it up without the doors attached. Anyway, it's got 120vac to the inverter but I have no idea what should be going to the main control pcb, or if it's getting or sending a signal. If someone knows where and what ac/dc values I should be looking for I would be able to determine what I can fix or if I should call a tech. Additionally, there are no lights coming on at all,no fans, no compressor, nothing. It does pull amperage when plugged in but nothing comes on. Is there a reset sequence? Cold reset, hard reset, etc? Know where I can get a P2P diagram? Thanks, :confused:
