Does the Amana SDI25E-L refrigerator have a start relay? What is the difference between a start relay and a "Relay K" for this model? Does anyone know the part number for replacement of this relay? We have already replaced the defrost timer but the only thing left is the start relay? The refrigerator has water in front of it and the temperature of the freezer and the refrigerator compartment keeps going up? Any help would be appreciated. Thanks.:confused:
I would try a AP4503032 start device on this if the compressor is warm, but not running. If the compressor is not warm, you have no voltage to it. All the "older" compressors had the compressor pinout as follows. Common pin on top, start pin, bottom left, run pin bottom right. Should monitor the start up current with an amprobe if you have one.
