Discuss
refrigerator-freezer
 in
Refrigerator & Freezer Repair
Hello, The freezer works but the frig does not cool. Can you help ? T. Y.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator-freezer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-19-2007, 08:21 AM
Dort Dort is offline
Junior Member
Dort is on a distinguished road
Default refrigerator-freezer
Model Number: FCD-12TJ   Brand: Frigidaire   Age: More than 10 years
Hello,
Can you help ?
T. Y.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-19-2007, 10:14 AM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default model?
Can you recheck that model number, I'm not seeing this one anywhere... Be sure to include all the characters from the id tag/plate... Usually the cubit feet are placed in the model number; your example would exhibit a 12 cu ft refrigerator... I'm 5'6" and could easily look over the top of a 12 cu ft fridge...
post back...
__________________
  #3 (permalink)
Old 11-19-2007, 10:45 AM
Senior Expert
APP Volunteer
Default ok found it
I did find some FCD12TF** models.. If yours is similar then it's a unit with an evaporator coil in the freezer/fridge compartments that you manually defrost... If the cold plate in the rear of the fridge is not frosted or cold to the touch then you may have a low refrigerant charge or restriction in the system... Would take someone refrigerant-handling certified to repair... Is the compressor running constantly?? If the fridge compartment is warm then the thermostat would have the compressor running continuously... Check the frost buildup in the freezer, is it mostly on one side or is it evenly building up on the evaporator walls... post back, kooler
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator & Freezer warm GaryS Refrigerator & Freezer Repair 1 11-14-2007 11:34 AM
Refrigerator / Freezer not cooling dbgtrek Refrigerator & Freezer Repair 0 10-18-2007 11:44 AM
Refrigerator/Freezer Steve1 Refrigerator & Freezer Repair 0 08-20-2007 06:12 PM
refrigerator freezer douville Refrigerator & Freezer Repair 8 08-14-2007 09:18 AM
Refrigerator/Freezer Caroline42 Refrigerator & Freezer Repair 1 07-20-2007 04:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
