Discuss
GE Arctica Touchpad Control
 in
Refrigerator & Freezer Repair
Several of the buttons on my GE Arctica control panel do not work. It looks like from the exploded diagram
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Arctica Touchpad Control
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-19-2007, 07:28 AM
sbellner sbellner is offline
Junior Member
sbellner is on a distinguished road
Default GE Arctica Touchpad Control
Model Number: PSS25NGMAWW   Brand: GE   Age: 1 - 5 years
Several of the buttons on my GE Arctica control panel do not work. It looks like from the exploded diagram I need part callout 421. This is AppliancePartsPros no. AP3796807
This part is called a electronic service kit, and it looks like it replaces both the temp control board (behind the pushbuttons), and the main board. But I can't tell if it replaces the buttons. It looks like the right trim piece, but there is not a front view. Is this the part I need?
For what it's worth, there is also a part callout 424, which is the current temp control board I have. I cannot troubleshoot any farther until I get the button problem resolved, as I can't change the freezer temp, nor can I put the unit in diagnostic mode.
Steve B.
Last edited by sbellner : 11-19-2007 at 07:31 AM. Reason: Changed part reference from link to number.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-19-2007, 07:32 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Steve
The part with number AP3796807 , called an electronic service kit, included a redesigned main control board and a redesigned user interface and this is a part which you need first.
If you have more than this one problems with your fridge, then you can run any tests. Let me know if you need an instructions.
- Here are the break down diagrams for the GE refrigerator Model PSS25NGMAWW
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 11-19-2007, 07:52 PM
Junior Member
Default
Thanks Gene. That's what I suspected, but I couldn't find any documentation supporting that assumption. Does it use the same wiring harness, or is this part of the service kit? I'll find out soon, because the kit is being ordered right now!
  #4 (permalink)
Old 11-19-2007, 07:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Fortunately it does not need any rewiring.
__________________
  #5 (permalink)
Old 12-01-2007, 08:06 PM
Junior Member
Default Electronics Assembly Worked Like a Charm
Thanks, Gene for your advice. The electronics retrofit worked beautifully. While I had the unit down, I decided to check the FF damper assembly, and as I expected, the damper door was broken like so many others have reported. Some superglue and a little teflon spray had the damper working again, but I don't know how long this fix will last. As of a few minutes ago, both freezer and FF cabinets were spot-on their temp setpoints, so at least for now, everything is working great.
  #6 (permalink)
Old 07-08-2008, 01:30 PM
slain1 slain1 is offline
Junior Member
slain1 is on a distinguished road
Default GE Model pss25ngma ww side by side
I just got done replacing the ice maker module on my GE side by side. The old unit didn't light up and i feared that it was probably damaged by the lightning storm that we had earlier. the new unit lights up, but I am still unable to make ice. is there anything else in the system that i need to check. If so, what is it, how do I check it, and where is it located.
thanks,
slain.
  #7 (permalink)
Old 07-08-2008, 01:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by slain1 View Post
...The old unit didn't light up and i feared that it was probably damaged by the lightning storm that we had earlier. the new unit lights up...
Hi Slain,
Did you mean green LED on the ice maker? Does it stay solid while the ice maker is on?
What is the part number for the new ice maker?
__________________
  #8 (permalink)
Old 07-08-2008, 04:55 PM
Junior Member
Default
Gene,
Yes the green LED remains lit while the ice maker is switched on, however, there is no ice produced. I don't know if any water is coming into the ice maker. The water dispenser on the door does dispense water though. The part number of the ice maker is WR30X10061. The original ice maker part number that was in the fridge was WR30X10012.
Slain.
  #9 (permalink)
Old 07-08-2008, 06:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Slain,
Where did you get this ice maker from?
GE replaced this electronic ice maker with new electromechanical due to too many problems with the old one. The part number for new ice maker is WR30X10093 which is AppliancePartsPros.com item number AP4345120.
Check for continuity the solenoid on the water inlet valve and if there is nothing wrong then you probably need another ice maker.
__________________
  #10 (permalink)
Old 07-08-2008, 07:52 PM
Junior Member
Default Solenoid location
Gene,
The breakout diagram shows the solenoid in the freezer door front. If that is truly where it is located, I have no idea how to gain access to it. Could you provide some guidance.
Thanks,
Al.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Profile Arctica nguyenbn Refrigerator & Freezer Repair 14 08-14-2008 08:47 AM
Maytag Dishwasher - no lights to touchpad philfrommaine Dishwasher Repair 1 01-04-2008 05:11 PM
Touchpad mirmax Oven Repair (including Ranges and Cooktops) 1 08-17-2007 08:07 AM
GE Profile Arctica Water Line taximomuv3 Refrigerator & Freezer Repair 0 08-14-2007 03:31 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
