Discuss
GE Arctica Touchpad Control
 in
Refrigerator & Freezer Repair
I meant the water valve solenoid which should be on the back of the refrigerator behind the cover. The incoming
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Arctica Touchpad Control
  #11 (permalink)
Old 07-08-2008, 11:57 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I meant the water valve solenoid which should be on the back of the refrigerator behind the cover. The incoming water line should be connected to this water valve.
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 07-09-2008, 04:15 PM
slain1 slain1 is offline
Junior Member
slain1 is on a distinguished road
Default Valve Check
Gene,
I checked the valves in the back of the fridge with my multimeter. There are a total of four valves, two blue and two red. The two blue ones read 168 ohms for the first valve and 338 ohms for the second valve. The red valves didn't register any resistance for either valve. I hope that the red valves are what controls the water to the ice maker and the blue valves control the water for the door. If that is true, then I am certain this is the reason why my new ice maker isn't making any ice. Please let me know if you agree so that I can order the replacement part.
Thanks,
Al.
  #13 (permalink)
Old 07-09-2008, 04:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can easy find out if these coils are for the ice maker by the size of the plastic tubes connected. 1/4" - ice maker, 5/16" - water dispenser.
__________________
  #14 (permalink)
Old 07-09-2008, 05:44 PM
Junior Member
Default
Gene,
The red coils are indeed the 1/4" ones. Therefore, they go to the ice maker. I will order the part and update the thread if all goes well. Thanks for all your help.
Al.
  #15 (permalink)
Old 07-14-2008, 08:47 PM
Junior Member
Default
Gene,
I just replaced the valve assembly and everything seems to be working fine. Thanks for all your help and guidance.
Al
  #16 (permalink)
Old 07-14-2008, 10:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Al,
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Profile Arctica nguyenbn Refrigerator & Freezer Repair 14 08-14-2008 09:47 AM
Maytag Dishwasher - no lights to touchpad philfrommaine Dishwasher Repair 1 01-04-2008 06:11 PM
Touchpad mirmax Oven Repair (including Ranges and Cooktops) 1 08-17-2007 09:07 AM
GE Profile Arctica Water Line taximomuv3 Refrigerator & Freezer Repair 0 08-14-2007 04:31 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
