Discuss
amana SDC25TL side by side coil frozen..why?
 in
Refrigerator & Freezer Repair
I have an amana sdc25tl side by side fridge. the coil in the freezer is frozen over. it seems the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » amana SDC25TL side by side coil frozen..why?
  #1 (permalink)
Old 11-18-2007, 05:08 PM
Junior Member
weel is on a distinguished road
Default amana SDC25TL side by side coil frozen..why?
Model Number: SDC25TL   Brand: Amana   Age: More than 10 years
I have an amana sdc25tl side by side fridge. the coil in the freezer is frozen over. it seems the fan to circulate air is not working. i have checked the ohms on the defrost coil and get 28.6 ohms. so i think that is good. the defrost thermostat looks like it might be coming apart. it looks like a pop can does when it is frozen. however 120 volts does pass thru it, when it is not touching the coil. if that makes sense. when the thermostat is hooked to the coil "physically" it does not let 120 volts pass thru. i think this might be my problem but im not sure. can i bypass this timer to see if it works without frying anything.
looking at the wires it looks like the power goes as follows
from defrost coil to defrost thermostat to fan.
i read where people talk about a defrost timer to adjust but i don see one where im looking..
thanks in advance bill
Ads By Google
Related Models
Maytag SDE2606AYW DRYER- ELE
Maytag SDE305DAYW DRYER- ELE
Maytag SDE305DAZW DRYER- ELE
Maytag SDE3606AYQ DRYER- ELE
Maytag SDE3606AYW DRYER- ELE
Maytag SDE3606AZW DRYER- ELE
Maytag SDE4000AYW DRYER- ELE
Maytag SDE4000AZW DRYER- ELE
Maytag SDE405DAYW DRYER- ELE
Maytag SDE4606AYW DRYER- ELE
Maytag SDE4606AZW DRYER- ELE
Maytag SDE505DAYQ DRYER- ELE
Maytag SDE505DAYW DRYER- ELE
Maytag SDE505DAZW DRYER- ELE
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
  #2 (permalink)
Old 11-18-2007, 06:10 PM
Junior Member
Default
well i jumped the defrost thermostat and the fan spins like a champ. so im guessing that the defrost thermostat is bad. in comparing it with pictures of the ones that are new. i think mine came apart for some reason. if anyone has any other ideas shoot me a line...
i dont have the part number for the defrost thermostat. if anyone can point me in the right direction ?????
bill
  #3 (permalink)
Old 11-18-2007, 09:27 PM
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default model?
Congrats, it appears you may have figured this one out on your own... Altho I can't locate a parts list with the model number you listed.. Are there any characters on the tag that you left out?? And normally you won't find a timer mounted in the freezer compartment tho some models do... It's usually inside the fridge or underneath... Need more info to id a part number for you... cheers, kooler
__________________
  #4 (permalink)
Old 11-19-2007, 08:14 PM
Junior Member
Default
kooler thanks for the reply. i found a new one at a parts store for 23.00 and it is working like a champ.. i just thought there might have been another solution or another problem that im not seeing. and it figures i just had shoulder surgery two weeks ago so i had to have a friend who is not famaliar with a meter and scared of electricity do the work for me,.
well its done. thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water dispenser line frozen in door-GE side/side JenniferL Refrigerator & Freezer Repair 0 09-27-2009 11:46 AM
amana side by side running constantly barely cold enough TOOLMANTCF Refrigerator & Freezer Repair 0 07-01-2009 05:18 PM
amana refrigerator side by side Model # SXD22S2W mfg # P1190416WW rockyroad Refrigerator & Freezer Repair 1 05-04-2009 03:24 PM
Motor next to Compressor burnt - Amana Side by Side Refrigerator hlitebrite Refrigerator & Freezer Repair 4 03-03-2009 08:49 AM
Side by Side freezer coil iceing over bksbjmds8 Refrigerator & Freezer Repair 2 07-25-2007 12:27 PM
