Discuss
Refridgerator runs all the time
 in
Refrigerator & Freezer Repair
I had a cooling problem last week in my fridge. The freezer was ice cold, but the fridge was at
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refridgerator runs all the time
  #1 (permalink)
Old 06-30-2011, 10:28 PM
PSI PSI is offline
Junior Member
PSI is on a distinguished road
Default Refridgerator runs all the time
Model Number: FRS26ZPHD2   Brand: Frigidaire   Age: More than 10 years
I had a cooling problem last week in my fridge. The freezer was ice cold, but the fridge was at room temperature. I tested the timer with a multimeter and it was bad. I tested the defrost heater cable and it was bad too. After I pulled it out and looked at it, it was warped. The defroster heater cable must have went and blew the timer. I didn’t know how to check the thermostat, so I replaced it just in case.
The fridge has been cooling fine since, but a new problem has come up since repairing the cooling problem. The fridge runs all the time. I vacuumed off the evaporator cables, checked the seals on the fridge and freezer and they’re ok, pulled the fridge away from the wall to get good circulation around the condenser motor, the light switch in both the fridge and freezer turn off when depressed but it still runs constantly.
I’ve gotten the freezer to turn on and off by setting the control in the fridge to the normal setting, and by turning the dial in the freezer to the almost “off” position (Just before “off”) The fridge temperature is maintaining 40 degrees while the dial is at the normal setting and the freezer varies between 5 degrees and 20 degrees at the just before “off” setting. By doing this, the fridge does cycle on and off.
Is the new thermostat that I replaced when I had the cooling problem last week in the freezer bad? Low Freon or Freon leak? Damper Control bad? Any idea’s?
Related Models
Frigidaire FRS26ZPHD2 Frg(v1) / Refrigerator
Frigidaire FRS26ZPHD3 Frg(v2) / Refrigerator
Frigidaire FRS26ZPHD4 Frigidaire/refrigerator
Frigidaire FRS26ZPHQ2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZPHQ3 Frg(v3) / Refrigerator
Frigidaire FRS26ZPHQ4 Frigidaire/refrigerator
Frigidaire FRS26ZPHW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZPHW1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZPHW2 Frg(v2) / Refrigerator
Frigidaire FRS26ZPHW3 Frg(v4) / Refrigerator
Frigidaire FRS26ZPHW4 Frigidaire/refrigerator
Frigidaire FRS26ZRFB3 Frg(v0) / Refrigerator
Frigidaire FRS26ZRFD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZRFD1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZRFD2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZRFD3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZRFW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZRFW1 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26ZRFW2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZRFW3 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS26ZRGB0 Frg(v1)
Frigidaire FRS26ZRGB1 Frg(v1) / Refrigerator
Frigidaire FRS26ZRGB2 Frg(v2) / Refrigerator
Frigidaire FRS26ZRGB3 Frg(v1) / Refrigerator
Frigidaire FRS26ZRGB4 Frg(v1) / Refrigerator
Frigidaire FRS26ZRGB5 Frg(v1) / Refrigerator
Frigidaire FRS26ZRGB6 Frg(v2) / Refrigerator
Frigidaire FRS26ZRGB7 REFRIGERATOR
Frigidaire FRS26ZRGB8 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZRGB9 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZRGBA Frg(v1) / Refrigerator
Frigidaire FRS26ZRGBB Frg(v1) / Refrigerator
Frigidaire FRS26ZRGBC Frigidaire/refrigerator
Frigidaire FRS26ZRGD0 Frg(v2)
Frigidaire FRS26ZRGD1 Frg(v3) / Refrigerator
Frigidaire FRS26ZRGD2 Frg(v4) / Refrigerator
Frigidaire FRS26ZRGD3 Frg(v2) / Refrigerator
Frigidaire FRS26ZRGD4 Frg(v2) / Refrigerator
Frigidaire FRS26ZRGD5 Frg(v3) / Refrigerator
Frigidaire FRS26ZRGD6 Frg(v4) / Refrigerator
Frigidaire FRS26ZRGD7 REFRIGERATOR
Frigidaire FRS26ZRGD8 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZRGD9 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZRGDA Frg(v2) / Refrigerator
Frigidaire FRS26ZRGDB Frg(v2) / Refrigerator
Frigidaire FRS26ZRGDC Frigidaire/refrigerator
Frigidaire FRS26ZRGW0 Frg(v3)
Frigidaire FRS26ZRGW1 Frg(v5) / Refrigerator
Frigidaire FRS26ZRGW2 Frg(v6) / Refrigerator
Frigidaire FRS26ZRGW3 Frg(v3) / Refrigerator
Frigidaire FRS26ZRGW4 Frg(v3) / Refrigerator
Frigidaire FRS26ZRGW5 Frg(v5) / Refrigerator
Frigidaire FRS26ZRGW6 Frg(v6) / Refrigerator
Frigidaire FRS26ZRGW7 REFRIGERATOR
Frigidaire FRS26ZRGW8 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZRGW9 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZRGWA Frg(v3) / Refrigerator
Frigidaire FRS26ZRGWB Frg(v3) / Refrigerator
Frigidaire FRS26ZRGWC Frigidaire/refrigerator
Frigidaire FRS26ZSEB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSEB1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSEB3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSEB4 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSEW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSEW1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSEW3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSEW4 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSGB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSGB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSGB3 Frg(v1) / Refrigerator
Frigidaire FRS26ZSGB4 Frg(v2) / Refrigerator
Frigidaire FRS26ZSGW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSGW2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSGW3 Frg(v3) / Refrigerator
Frigidaire FRS26ZSGW4 Frg(v4) / Refrigerator
Frigidaire FRS26ZSHB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSHB1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSHB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZSHB3 Frg(v1) / Refrigerator
Frigidaire FRS26ZSHB4 Frg(v1) / Refrigerator
Frigidaire FRS26ZSHB5 REFRIGERATOR
Frigidaire FRS26ZSHW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSHW1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSHW2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZSHW3 Frg(v2) / Refrigerator
Frigidaire FRS26ZSHW4 Frg(v2) / Refrigerator
Frigidaire FRS26ZSHW5 SIDE BY SIDE REFRIGERATOR
Frigidaire FRS26ZTHB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZTHB1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZTHB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZTHB3 Frg(v1) / Refrigerator
Frigidaire FRS26ZTHB4 Frg(v1) / Refrigerator
Frigidaire FRS26ZTHB5 Frigidaire/refrigerator
Frigidaire FRS26ZTHD0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZTHD1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZTHD2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZTHD3 Frg(v2) / Refrigerator
Frigidaire FRS26ZTHD4 Frg(v2) / Refrigerator
Frigidaire FRS26ZTHD5 Frigidaire/refrigerator
Frigidaire FRS26ZTHQ3 Frg(v0) / Refrigerator
Frigidaire FRS26ZTHQ4 Frg(v3) / Refrigerator
Frigidaire FRS26ZTHQ5 Frigidaire/refrigerator
Frigidaire FRS26ZTHW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZTHW1 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZTHW2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS26ZTHW3 Frg(v3) / Refrigerator
Frigidaire FRS26ZTHW4 Frg(v4) / Refrigerator
Frigidaire FRS26ZTHW5 Frigidaire/refrigerator
Frigidaire FRS26ZXHD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS26ZXHD1 Frg(v1) / Refrigerator
Frigidaire FRS26ZXHD2 Frg(v1) / Refrigerator
Frigidaire FRS26ZXHW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS26ZXHW1 Frg(v2) / Refrigerator
Frigidaire FRS26ZXHW2 Frg(v2) / Refrigerator
Frigidaire FRS28XGCB0 Frg(v4) / Refrigerator
Frigidaire FRS28XGCB1 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS28XGCD0 Frg(v5) / Refrigerator
Frigidaire FRS28XGCD1 Frg(v5) / Side By Side Refrigerator
Frigidaire FRS28XGCW0 Frg(v6) / Refrigerator
Frigidaire FRS28XGCW1 Frg(v6) / Side By Side Refrigerator
  #2 (permalink)
Old 07-01-2011, 03:40 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Check your evaporator coil frost pattern, half frosted, or heavy frost all over?
__________________
  #3 (permalink)
Old 07-01-2011, 04:36 AM
PSI PSI is offline
Junior Member
Default
There is hardly any frost buildup when the freezer condensor motor, the condensor fan, and evaporator fan kicks back off. I would describe the evaporator coils as dull gray, uniformally, evenly, "lightly frosted." all over, top to bottom when the fridge kicks off.
One other thing that I noticed. I have opened the freezer door at least a few times when I heard the motor kick off to check the temperature in the freezer and fridge. The tempertature in both has always been at about 20 degrees freezer/ 40 degrees fridge. Only once did I catch the freezer in the defrost cycle. I could see that the evaporator coils were "cherry red" through the vent on the back wall.
Another observation: The outside air temperature has been cool (70 degrees) and not humid for the past 2 weeks, so I wouldn't expect it to run continuously when I had the dials in the fridge and freezer set at the normal positions initially.
Last edited by PSI : 07-01-2011 at 06:41 AM. Reason: made the description more clear after posting
  #4 (permalink)
Old 07-01-2011, 07:02 AM
Senior Expert
APP Volunteer
Default
Your freezer should get down below zero if the system is "normal". Your fridg is running longer than normal and wasting a lot of energy.
I suspect a worn compressor, refrigerant leak, or both. Gauges and an amprobe would confirm. This assumes the condenser and condenser motor is ok.
__________________
  #5 (permalink)
Old 07-01-2011, 03:53 PM
PSI PSI is offline
Junior Member
Default
Is this what you mean by half-frosted? I just took this picture a minute ago. It's all frosted up except at the bottom where I circled it in red.
  #6 (permalink)
Old 07-01-2011, 04:09 PM
Senior Expert
APP Volunteer
Default
An accurate temperature reading in the freezer will tell me everything, measure and post.
__________________
  #7 (permalink)
Old 07-01-2011, 04:19 PM
PSI PSI is offline
Junior Member
Default
The fridge was turning on and off while it was in the warmest setting, but has been on for about 5 hours straight, so I turned the defroster on manually and I put the temperature control back to the normal setting. The defroster is on now. Should I wait 24 hours for things to stabilize or should I give you a reading in an hour or two?
  #8 (permalink)
Old 07-01-2011, 05:45 PM
Senior Expert
APP Volunteer
Default
An accurate freezer temperature is critical for evaluation, might want to wait till the temperature settles down.
__________________
  #9 (permalink)
Old 07-01-2011, 08:58 PM
PSI PSI is offline
Junior Member
Default
It's been about 4.5 hours (has enough time passed to get an accurate reading?) since I changed the setting in the freezer from the warmest position to the normal position. The freezer reads 31 degrees and the fridge reads 41 degrees. The evaporator coil is iced up on top and not on the bottom just like the picture I sent earlier. Everything in the freezer is soft (icecream, pizza, pretzels, cool whip etc. Even the ice cubes in the ice cube tray are turning into one big blob of ice.
Do you know what it could be and a ballpark number as to how much is it going to cost to get this fixed?
  #10 (permalink)
Old 07-02-2011, 03:25 AM
Senior Expert
APP Volunteer
Default
If all the fans are running, you have a sealed system problem. A worn compressor and refrigerant leak are suspects as I said before. Cost of repair, more than $600.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Runs All The Time jarnold Refrigerator & Freezer Repair 1 04-26-2010 06:19 PM
Runs all the time mcraegaelic Refrigerator & Freezer Repair 1 11-10-2009 06:54 AM
GE Profile Refridgerator water still runs after dispensing detmers Refrigerator & Freezer Repair 1 10-03-2009 09:54 AM
refridgerator not cooling but compressor runs bpetska Refrigerator & Freezer Repair 3 06-16-2009 07:15 PM
refrigerator runs all the time dcrutcher Refrigerator & Freezer Repair 2 02-25-2009 01:57 PM
