sview
#1 Posted : Tuesday, March 10, 2009 5:52:06 AM(UTC)
sview
This is a side by side refrigerator.
Water leaks from the water dispenser. Initially if we adjust the dispenser by pulling up it use to stop. Now it drips at a rate of about 16 oz overnight.
What part do i replace and how?
Thank you.
TechnicianBrian
#2 Posted : Tuesday, March 10, 2009 6:05:59 AM(UTC)
TechnicianBrian
You may have a water valve that is not sealing completely, or air in the water line. There is also a fitting kit available for your refrigerator that can also help prevent slow leaks. I wrote about this problem in my post Kitchenaid Refrigerator Leaking Water Dispenser that may help with your problem.
sview
#3 Posted : Tuesday, March 10, 2009 9:16:58 AM(UTC)
sview
Thank you Brian.
I will try this home tonight. I did replace the filter about a month ago and disposed about two gallons of water right away. I will try to redo this again and see if this goes away. How do i find out what part# is for the fitting kit?
