Discuss
Won't Dispense Water
 in
Refrigerator & Freezer Repair
My Kenmore Elite refrigerator won't dispense water but the icemaker is working. I assume that means that either the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Won't Dispense Water
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-17-2007, 07:56 PM
SteveC SteveC is offline
Junior Member
SteveC is on a distinguished road
Default Won't Dispense Water
Model Number: 50502990   Brand: Kenmore   Age: 5 - 10 years
My Kenmore Elite refrigerator won't dispense water but the icemaker is working. I assume that means that either the switch in the door is bad or that the water inlet valve is bad. I assume from reading other posts that the quickest way to find which is bad is to see if voltage is getting to the valve. Correct?
How do I get to the valve? Is it exposed or do I need to remove a cover or other parts to get to it? Looking at the back, where will it be? How do I recognize it? Will there be a connector I can disconnect to check for voltage? What am I looking for: Ac or DC? What voltage?
Can you tell me the correct part numbers for the valve and the switch? The model number, 50502990 doesn't look like a typical Sears part number.
thanks,
SteveC
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 09:49 AM
christopherjamesodonnell@ christopherjamesodonnell@ is offline
Junior Member
christopherjamesodonnell@ is on a distinguished road
Default
my kenmore would stop dispending if I set the fridge below 42 degrees freeze up in th filter housing. this late caused a flood.
  #3 (permalink)
Old 02-06-2008, 09:43 AM
CHARLEY CHARLEY is offline
Junior Member
CHARLEY is on a distinguished road
Default
My dishwasher sears kenmore model # 363.16121100 won't drain water
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer wont dispense softner emmett Washer Repair 0 10-25-2007 11:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
