| » Freezer and Fridge not cooling/freezing |
Model Number: gs6sHAXKB01 Brand: Whirlpool Age: 5 - 10 years
Hello,
My fridge and freezer are no longer cooling freezing. Fans are blowing and I suspect the compressor has gone out. Is it possible this is just a starter problem? How would I diagnose the difference between a starter problem and a compressor problem. -thank you for your time. |
Quote:
Quote:
This tells you it is ether a bad start relay or a bad compressor. At this point I use a meter to see if the compressor is shorted to ground. If the compressor is not shorted then replace the start relay and give it a try. You should hear the compressor start right away with a new start relay if that was the problem. If the compressor is shorted to ground you will need to have the compressor replaced. Given the history on whirlpool side by side refrigerators in the 5 year old age range I would say it is a really good chance that a new start relay will fix your refrigerator. Whirlpool Refrigerator Start Relay Repair Guide
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog. |
Quote:
If the start relay is bad you will hear it try to start the compressor and then click off. Quote:
__________________
I have a similar problem with my Amana SxS. I too am hearing the click about ever 30 seconds. I have what I belive is a solid state (no coil)starting relay and it does not rattle when I shake it. I also checked the compressor for a short to ground. One of the three pins on the compressor that I checked gives me a reading of .000 (Ohm) on my mulitmeter. This is telling me that this pin is indeed shorted to ground right? The other two pins are giving me a "1." reading on my multimeter which would mean they are not shorted to ground. I am at work and do not have a model number available at this time.
| Display Modes | |
| Refrigerator not cooling, but freezer is working | geri | Refrigerator & Freezer Repair | 18 | 09-18-2008 03:49 PM |
| Kenmore fridge - water drips into fridge | njblue55 | Refrigerator & Freezer Repair | 3 | 08-07-2007 08:50 PM |
| Refer side not cooling properly, freezer okay | lynbo11 | Refrigerator & Freezer Repair | 0 | 07-30-2007 08:02 AM |
| freezer coil freezing | trey1122 | Refrigerator & Freezer Repair | 1 | 07-20-2007 06:27 PM |
| Hot Frame between Fridge and Freezer | mshilko | Refrigerator & Freezer Repair | 3 | 07-20-2007 01:57 PM |
