I've got a Whirlpool TS25AW side by side fridge, and I don't seem to locate any numbers after them anyplace, so I can't be more exact. My freezer is turning the ice cream into soup. From other posts and research I've more or less decided that the Start relay is bad.
My start relay has four spade connectors going to it, with blue, red, and white wires, however when I go to the Whirlpool parts pages, what I have doesn't seem to match anything on those pages.
Also how do I remove it from the Compressor? Does it just pull out of the compressor?
Originally Posted by: jimk11 ...From other posts and research I've more or less decided that the Start relay is bad... Can you describe your troubleshooting more detailed? The Model Number Locator can help you to find the complete model number. Gene.
