| » GE ice inside freezer door and motor always running |
Model Number: GSS25QGMDBB Brand: GE Age: 5 - 10 years
GE Refrigerator Model #GSS25QGMDBB. Droplets of ice are appearing on the very top of the freezer and ice is also building up on the top shelf. All of the ice is towards the front of the freezer closest to the door. Also, the motor seems to run almost constantly.
I checked the temp and it is running at negative 11 degrees Farenheit. I also checked the door seal and I dont feel any cool air coming out of the freezer. If I remember right, the freezer used to sound like it was sealing when you closed the door (sounded like air being drawn in or pushed out). I notice that it no longer does this. I had this similar problem before and a thermostat was replaced in the freezer. Could this thermostat be bad again or is it maybe just a bad door seal even though the door seal looks in good shape and is not stiff or cracked? Any help is appreciated. Thank you. Ads By Google Related Models |
| Display Modes | |
| GE 20 CF freezer with frost around the inside of door | AllenRhein | Refrigerator & Freezer Repair | 7 | 07-20-2010 09:15 PM |
| Ice Buildup Inside Freezer Door? | s31248 | Refrigerator & Freezer Repair | 2 | 04-20-2010 07:22 AM |
| water leak inside freezer door | ellioje1 | Refrigerator & Freezer Repair | 0 | 02-18-2010 07:06 PM |
| motor is running but refrigerator and freezer are not cooling | marnita61 | Refrigerator & Freezer Repair | 1 | 10-26-2009 05:06 PM |
| inside freezer door freezing | cdreece | Refrigerator & Freezer Repair | 2 | 06-13-2008 01:45 PM |
