Problem having is temp in fridge and freezer are way off. Freezer temp is -14 degree on display readout. Fridge temp is 34 degree on display panel. Actual temp with temp probe is freezer 15.1 deg. and fridge 61.9 deg. Checked defrost cycle. No frost buildup on back panel or coils. I had a power outtage on Thurs. 6/23/2011 and ever since then the temp. has been messed up. Any help is appreciated:confused: Thank you. Frank R
