Discuss
Fridge not cooling, fan and compressor are running
 in
Refrigerator & Freezer Repair
I have a side by side frigidaire. The compressor is running, the two fans are blowing, but the evaporator is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge not cooling, fan and compressor are running
  #1 (permalink)
Old 06-26-2011, 10:15 AM
Junior Member
gilbertwa001 is on a distinguished road
Default Fridge not cooling, fan and compressor are running
Brand: Frigidaire   Age: 1 - 5 years
I have a side by side frigidaire. The compressor is running, the two fans are blowing, but the evaporator is not cooling. Am wondering if the system is out of freon, but there are no leaks. Any ideas?
Ads By Google
  #2 (permalink)
Old 06-26-2011, 03:27 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Could be the compressor itself or all the freon has leaked out or a blockage in the sealed system.
In any case this will be an expensive repair as you need a pro. Also there is no guarantee of a long term fix.
Often it makes more sense to put those dollars toward a new unit.
I would check the warranty on the unit as the sealed system is often covered for longer than one year.
Be sure to read the fine print.
__________________
  #3 (permalink)
Old 06-27-2011, 06:12 PM
Junior Member
Gramps7053 is on a distinguished road
Default
Sounds like freon loss, but pull plug and leave off for 24 hours with door open and try again
Good luck,
G G Gra
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator not cooling, fan working, compressor hot but not running Andreyvol Refrigerator & Freezer Repair 52 04-05-2013 02:51 PM
Not cooling. Compressor bumps on then off. Fans running. afterhourstvrepair Refrigerator & Freezer Repair 3 12-30-2012 11:28 AM
Fridge/Freezer Not Cooling, Compressor Hot ryanej Refrigerator & Freezer Repair 3 06-09-2011 10:54 AM
'Fridge Compressor Not Running ricardo Refrigerator & Freezer Repair 1 03-28-2009 07:41 PM
compressor hot, fridge and freezer not cooling jeansto Refrigerator & Freezer Repair 19 10-29-2008 06:50 AM
