Discuss
Ice Maker Overflows
 in
Refrigerator & Freezer Repair
I have a Whirlpool Model GD25DIXHT02. I just replaced the water inlet valve and now my Ice Maker is overflowing
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Overflows
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-16-2007, 08:48 AM
Capt Steve Capt Steve is offline
Junior Member
Capt Steve is on a distinguished road
Default Ice Maker Overflows
Model Number: GD25DIXHT02   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool Model GD25DIXHT02. I just replaced the water inlet valve and now my Ice Maker is overflowing slightly and spilling down into the freezer. Not a flood, but enough to form icecicles on the bottom of the ice maker and puddles of ice on the top shelf. Everything else is working properly, it makes ice, ejects it and refills. The ice cubes are sometimes stuck together at the top, also indicating an overfill condition.
Before the valve went bad, it never overflowed. The new valve was the updated quck connect type. I checked the parts listing for the ice maker and I don't see where there are any adjustments or electronics on the Ice Maker itself. There are two PC boards located on either side of the freezer, both part # AP137510, but they appear to be photo emitters and receivers only. There is also a switch on the right side that turns the ice maker on and off, but again I do not see any place to make adjustments.
My questions are;
1. Is there an adjustment for fill time and where is it?
2. If there is no adjustment, what controls how long the inlet valve is energized?
3. Is there a way to manually cycle the ice maker, and what tests can be preformed?
4. What else could be causing this condition?
Thank you for any assistance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 04:18 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The water level adjustment screw should be under the ice maker front cover. Remove the ice maker, remove the front cover and turn the screw half way clock wise.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer overflows Jhazel Washer Repair 0 11-13-2007 06:23 AM
washer overflows mbrown211 Washer Repair 0 10-12-2007 11:17 AM
washer drain overflows tolbsplace Washer Repair 0 09-28-2007 05:02 AM
Fill cycle overflows jpcamping Washer Repair 0 09-24-2007 10:41 AM
cold water overflows notsure Washer Repair 4 09-12-2007 06:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
