Discuss
ice maker
 in
Refrigerator & Freezer Repair
my ice maker has quit. i checked the water supply and it is good. where do i go from here.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice maker
  #1 (permalink)
Old 06-22-2011, 01:16 PM
Junior Member
cjohns is on a distinguished road
Default ice maker
Model Number: mbf2556keb   Brand: Maytag   Age: 1 - 5 years
Related Models
Maytag MBF2556KEB REF - BOTTOM MOUNTS
Maytag MBF2556KEB11 REFRIGERATOR
Maytag MBF2556KEB3 REFRIGERATOR
Maytag MBF2556KEQ REF - BOTTOM MOUNTS
Maytag MBF2556KEQ11 REFRIGERATOR
Maytag MBF2556KEQ3 REFRIGERATOR
Maytag MBF2556KEW REF - BOTTOM MOUNTS
Maytag MBF2556KEW11 REFRIGERATOR
Maytag MBF2556KEW3 REFRIGERATOR
Maytag MBF2558HEB REF - BOTTOM MOUNTS
Maytag MBF2558HEQ REF - BOTTOM MOUNTS
Maytag MBF2558HES REF - BOTTOM MOUNTS
Maytag MBF2558HEW REF - BOTTOM MOUNTS
Maytag MBF2562HEB REF - BOTTOM MOUNTS
Maytag MBF2562HEB13 REFRIGERATOR
Maytag MBF2562HEQ REF - BOTTOM MOUNTS
Maytag MBF2562HEW REF - BOTTOM MOUNTS
Maytag MBF2562HEW13 REFRIGERATOR
Maytag MBL1952KES REF - BOTTOM MOUNTS
Maytag MBL1952KES12 REFRIGERATOR
Maytag MBL1952KES3 REFRIGERATOR
Maytag MBL1953WES1 REFRIGERATOR
Maytag MBL1953WES2 REFRIGERATOR
Maytag MBL1953WES3 REFRIGERATOR
Maytag MBL1953XES0 REFRIGERATOR
Maytag MBL1956HES REF - BOTTOM MOUNTS
Maytag MBL1956HES14 REFRIGERATOR
Maytag MBL1956KES REF - BOTTOM MOUNTS
Maytag MBL1956KES12 REFRIGERATOR
Maytag MBL1956KES3 REFRIGERATOR
Maytag MBL1956KES4 REFRIGERATOR
Maytag MBL1956KES5 REFRIGERATOR
Maytag MBL1956KES6 REFRIGERATOR
Maytag MBL1957VES1 REFRIGERATOR
Maytag MBL1957VES10 REFRIGERATOR
Maytag MBL1957VES2 REFRIGERATOR
Maytag MBL1957VES3 REFRIGERATOR
Maytag MBL1957VES4 REFRIGERATOR
Maytag MBL1957WES0 REFRIGERATOR
Maytag MBL2255KES REF - BOTTOM MOUNTS
Maytag MBL2255KES12 REFRIGERATOR
Maytag MBL2256KES REF - BOTTOM MOUNTS
Maytag MBL2256KES12 REFRIGERATOR
Maytag MBL2256KES3 REFRIGERATOR
Maytag MBL2256KES4 REFRIGERATOR
Maytag MBL2256KES6 REFRIGERATOR
Maytag MBL2258XES0 REFRIGERATOR
Maytag MBL2262HES REF - BOTTOM MOUNTS
Maytag MBL2262KES REF - BOTTOM MOUNTS
Maytag MBL2262KES12 REFRIGERATOR
Maytag MBL2556KES REF - BOTTOM MOUNTS
Maytag MBL2556KES12 REFRIGERATOR
Maytag MBL2556KES4 REFRIGERATOR
Maytag MBL2556KES5 REFRIGERATOR
Maytag MBL2562HES REF - BOTTOM MOUNTS
Maytag MBL2562KES REF - BOTTOM MOUNTS
Maytag MBQ30 GAS GRILL - B/I STAINLESS ST
Maytag MBQ42 GAS GRILL - B/I STAINLESS ST
Admiral MBR1415AGS RANGE- F/S STD ELE
Admiral MBR1415AGW RANGE- F/S STD ELE
Maytag MBR1952KES REF - BOTTOM MOUNTS
Maytag MBR1952KES12 REFRIGERATOR
Maytag MBR1952KES3 REFRIGERATOR
Maytag MBR1953WES1 REFRIGERATOR
Maytag MBR1953WES2 REFRIGERATOR
Maytag MBR1953WES3 REFRIGERATOR
Maytag MBR1953XES0 REFRIGERATOR
Maytag MBR1956HES REF - BOTTOM MOUNTS
Maytag MBR1956HES14 REFRIGERATOR
Maytag MBR1956KES REF - BOTTOM MOUNTS
Maytag MBR1956KES12 REFRIGERATOR
Maytag MBR1956KES3 REFRIGERATOR
Maytag MBR1956KES4 REFRIGERATOR
Maytag MBR1956KES5 REFRIGERATOR
Maytag MBR1956KES6 REFRIGERATOR
Maytag MBR1957VES1 REFRIGERATOR
Maytag MBR1957VES10 REFRIGERATOR
Maytag MBR1957VES2 REFRIGERATOR
Maytag MBR1957VES3 REFRIGERATOR
Maytag MBR1957VES4 REFRIGERATOR
Maytag MBR1957WES0 REFRIGERATOR
Maytag MBR1980AAB SMALL APPLIANCES
Maytag MBR1980AAG SMALL APPLIANCES
Maytag MBR2255KES REF - BOTTOM MOUNTS
Maytag MBR2255KES12 REFRIGERATOR
Maytag MBR2256KES REF - BOTTOM MOUNTS
Maytag MBR2256KES12 REFRIGERATOR
Maytag MBR2256KES3 REFRIGERATOR
Maytag MBR2256KES4 REFRIGERATOR
Maytag MBR2256KES6 REFRIGERATOR
Maytag MBR2258XES0 REFRIGERATOR
Maytag MBR2262HES REF - BOTTOM MOUNTS
Maytag MBR2262KES REF - BOTTOM MOUNTS
Maytag MBR2262KES12 REFRIGERATOR
Maytag MBR2556KES REF - BOTTOM MOUNTS
Maytag MBR2556KES12 REFRIGERATOR
Maytag MBR2556KES4 REFRIGERATOR
Maytag MBR2556KES5 REFRIGERATOR
Maytag MBR2562HES REF - BOTTOM MOUNTS
Maytag MBR2562KES REF - BOTTOM MOUNTS
Admiral MBR4450BGH RANGE- F/S STD GAS
Admiral MBR4450BGW RANGE- F/S STD GAS
Admiral MBR4450CGH RANGE- F/S STD GAS
Admiral MBR5730BGW RANGE- S/C F/S GAS
Admiral MBR5750AGW RANGE- S/C F/S GAS
Maytag MBS1976AAB PERSONAL BEVERAGE CENTER
Maytag MBS1976AAP PERSONAL BEVERAGE CENTER
Maytag MBV1976AAB PERSONAL BEVERAGE CENTER
Maytag MBV1976AAP PERSONAL BEVERAGE CENTER
Thermador MBYB
Thermador MBYB AFTER S/N 8204
Thermador MBYS
Thermador MBYS AFTER S/N 8204
Thermador MBYW
Thermador MBYW AFTER S/N 8204
 MC1015BB MWAVE- CNTRTP / STAND ALONE
 MC1015UBB MWAVE- CNTRTP / STAND ALONE
 MC1015UWB MWAVE- CNTRTP / STAND ALONE
 MC1015WB MWAVE- CNTRTP / STAND ALONE
Frigidaire MC1020C0 Frg(v1) / Microwave Oven
  #2 (permalink)
Old 06-22-2011, 03:17 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
C,
You could have a bad fill valve.
But test the icemaker first.
You'll need a piece of tape and a short piece(2 or 3 inches long) of 14 guage wire.
*** Be careful when doing this test ***
Open the freezer door and get access to the icemaker.
Tape the freezer door light switch closed/down.
Remove the white plastic cover from the front of the icemaker assembly.
Strip 1/2 to 3/4 inches of the insulation off both ends of the wire.
Insert one end of the wire into the opening labeled "H", and the other end of the wire into the "T" opening(both openings are laocated in the bottom right corner of the module body face approx. 4 and 5 o'clock positions)
Make sure the ends of the wires are in deep enough to contact the internal contacts in the module.
once the main gear starts to rotate, remove the wire.
* If the gear does not start to rotate in a few seconds, you'll need to replace the icemaker.*
Part number: AP4135008
If the main gear rotates and the rake arm moves, at the 3 to 9 o'clock the heater should activate and you should be able to feel the heat from the bottom of the ice maker.
At the 1 to 2 o'clock position, the icemaker should fill with water, or you may hear a buzz from the fill valve, but no water would indicate a bad fill valve.
Part number: AP4303451
You should have this issue figured out in a few minutes, and on the way to repairing the fridge.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New ice maker installed but no water running to ice maker corona32guiness Refrigerator & Freezer Repair 0 01-06-2010 05:14 PM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:27 AM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:20 AM
GE tube ice maker freezing but ice maker works dhayden Refrigerator & Freezer Repair 1 09-05-2009 08:54 AM
Replaced Ice Maker and noid and still no water to ice maker darrewhite Refrigerator & Freezer Repair 0 05-17-2009 06:34 AM
