refrigerator is not cooling top and bottom
Originally Posted by: gthor11 refrigerator is not cooling top and bottom blowing warm air instead
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Here are your parts Replacement parts for FRT22RHADO models | AppliancePartsPros.comFirst you have to determine if the compressor is running. You can usually hear it and you should be able to feel it vibrating and it should be warm. If it running and the fans are also running and there is no frost on the evaporator coils in the freezer then you have a sealed system problem. This will be an expensive repair as you need a pro often it makes more sense to put those dollars towards a new unit. If it is not running it could be you are stuck in defrost, a control (thermostat) problem, a compressor start problem, a bad wire connection or a compressor problem. Here is a good link with basic fridge troubleshooting/repair info. http://www.applianceaid.com/frig.html |
THIS FORUM IS DEAD!!!!!!! |
