I have replacement water filter head for Amana SRD26VW. It comes with 2 screws, but I see no screw holes on the head. Is the head some how fitted into the protective housing which uses the screws? Also not sure how to connect in and out water line? Seems to be some sort of compression connector. Do you just pull lines out of old head and force into new head? There is nothing to turn or screw. Any help with this would be appreciated.
Warren Reese
