| » Water inlet valve |
Model Number: ED22TEXHW00 Brand: Whirlpool Age: 5 - 10 years
I just purchased a new water inlet valve, it is a three solenoid valve and the new part appears to have quick connect type water line fittings ( or something) on 3 of the outlets and 2 of the outlets use the threaded type water line connections on the new part ,, my old inlet valve uses threaded connections on all the water lines on the valve, the valve looks the same except for how the water lines connect to the new valve , do I have a wrong part ? how do I connect the lines ? or should I send it back for a return , it's useless the way it is out of the box since my frige uses all threaded type water line connections ..... any help or info would be much appreciated .................. thanks
Related Models Last edited by m/c : 07-31-2007 at 12:40 AM. |
There should have been some instruction in the box.
Does your new valve have fittings like the one in this video? Video: Connect and disconnect a push-in ice maker water fill valve plastic line If so then you cut your old plastic nut ends off and slip the line into the new valve. Hope that helps, |
| Display Modes | |
| water valve wiring hotpoint/ge | Cuch | Washer Repair | 2 | 07-24-2007 06:29 PM |
| water flow valve | BRAND001 | Washer Repair | 0 | 07-23-2007 08:05 PM |
| Ge inlet valve | Mark | Dishwasher Repair | 1 | 07-20-2007 07:22 PM |
| Water inlet valve | gentleben | Refrigerator & Freezer Repair | 1 | 07-19-2007 12:04 PM |
