Discuss
Compressor not turning on
 in
Refrigerator & Freezer Repair
Symptoms: No cooling at all in freezer or refrigeration section. All interior and exterior fans/lights/etc work fine, but internal temp
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor not turning on
  #1 (permalink)
Old 03-04-2009, 02:39 AM
Junior Member
goldenbear is on a distinguished road
Default Compressor not turning on
Model Number: PLHS267ZAB5   Brand: Frigidaire   Age: 5 - 10 years
Symptoms: No cooling at all in freezer or refrigeration section. All interior and exterior fans/lights/etc work fine, but internal temp is at a nice warm 72F. The compressor hums for a few seconds, then shuts off with a soft click, then repeats after a few minutes. The top of compressor is very warm/hot after this goes on a few hours.
This has happened about five times since last summer. Generally, the fridge starts working again after anywhere from 1 day, 1 week, or 1 month (I once left it on for 2 weeks, gave up and turned it off for a month, turned it back on, then it started working after 1-2 days). I was working 7 days, up to 85 hrs/week at the time, so I really didn't need a working fridge.
I actually never noticed the compressor not running before this latest incident. It could be that it wasn't running the other times and I mistook the fan noise for the compressor. Or it could be a new wrinkle.
Anyway, after reading a LOT of posts, it looks like the problem with the compressor not running is most likely either the relay, capacitor, compressor, or some combination of the three.
Capacitor:
I tried checking the resistance of the capacitor. I read some resistance value for less than a second, then the meter reads no continuity and stays that way (I stopped after about 10 seconds). Does this mean I've got a bad capacitor, or am I doing something wrong with how I'm taking the measurement?
Compressor:
I checked the resistance between compressor pins and from pin to ground. Got a very low resistance (almost zero, I think) between pins and no continuity from pins to ground. So, is it safe to assume the compressor is good?
Relay:
The wires are recessed into the relay housing, so they rattle against the housing, which means I can't tell if something else is rattling. Is there some other way to test the relay? Better yet, how do I pull the wires out of the relay housing?
Is there anything else I should be checking?
Any advice would be greatly appreciated.
Ads By Google
Related Models
Frigidaire PLHS267ZAB5 Frigidaire/refrigerator
Frigidaire PLHS267ZAB6 Frigidaire/refrigerator
Frigidaire PLHS267ZCB0 Frigidaire/refrigerator
Frigidaire PLHS267ZCB1 Frigidaire/refrigerator
Frigidaire PLHS267ZCB2 Frigidaire/refrigerator
Frigidaire PLHS267ZCB4 Frigidaire/refrigerator
Frigidaire PLHS267ZDB0 Frigidaire/refrigerator
Frigidaire PLHS267ZDB1 Frigidaire/refrigerator
Frigidaire PLHS267ZDB2 Frigidaire/refrigerator
Frigidaire PLHS267ZDB3 Frigidaire/refrigerator
Frigidaire PLHS267ZDB4 Frigidaire/refrigerator
Frigidaire PLHS267ZDB5 Frigidaire/refrigerator
Frigidaire PLHS267ZDB6 Frigidaire/refrigerator
Frigidaire PLHS267ZDB7 Frigidaire/refrigerator
Frigidaire PLHS268ZCB0 Frigidaire/refrigerator
Frigidaire PLHS268ZCB1 Frigidaire/refrigerator
Frigidaire PLHS268ZCB2 Frigidaire/refrigerator
Frigidaire PLHS268ZCB3 Frigidaire/refrigerator
Frigidaire PLHS268ZCB4 Frigidaire/refrigerator
Frigidaire PLHS269ZCB0 Frigidaire/refrigerator
Frigidaire PLHS269ZCB1 Frigidaire/refrigerator
Frigidaire PLHS269ZCB2 Frigidaire/refrigerator
Frigidaire PLHS269ZCB3 Frigidaire/refrigerator
Frigidaire PLHS269ZCB4 Frigidaire/refrigerator
Frigidaire PLHS269ZDB0 Frigidaire/refrigerator
Frigidaire PLHS269ZDB1 Frigidaire/refrigerator
Frigidaire PLHS269ZDB2 Frigidaire/refrigerator
Frigidaire PLHS269ZDB3 Frigidaire/refrigerator
Frigidaire PLHS269ZDB4 Frigidaire/refrigerator
Frigidaire PLHS269ZDB5 Frigidaire/refrigerator
Frigidaire PLHS269ZDB7 Frigidaire/refrigerator
Frigidaire PLHS269ZDB9 Frigidaire/refrigerator
Frigidaire PLHS269ZDBA Frigidaire/refrigerator
Frigidaire PLHS269ZDBB Frigidaire/refrigerator
Frigidaire PLHS269ZDBC Frigidaire/refrigerator
Frigidaire PLHS269ZDBD Frigidaire/refrigerator
Frigidaire PLHS269ZDBE Frigidaire/refrigerator
Frigidaire PLHS269ZDBN Frigidaire/refrigerator
Frigidaire PLHS269ZDBP Frigidaire/refrigerator
Frigidaire PLHS280ZAB3 Frigidaire/refrigerator
Frigidaire PLHS280ZAB4 Frigidaire/refrigerator
Frigidaire PLHS280ZAB5 Frigidaire/refrigerator
Frigidaire PLHS37EESB0 Frigidaire/refrigerator
Frigidaire PLHS37EESB1 Frigidaire/refrigerator
Frigidaire PLHS37EESB2 Frigidaire/refrigerator
Frigidaire PLHS37EESB3 Frigidaire/refrigerator
Frigidaire PLHS37EESB5 Frigidaire/refrigerator
Frigidaire PLHS37EESB7 Frigidaire/refrigerator
Frigidaire PLHS37EESB9 Frigidaire/refrigerator
Frigidaire PLHS37EESBN Frigidaire/refrigerator
Frigidaire PLHS37EFSB0 Frigidaire/refrigerator
Frigidaire PLHS37EGSB0 Frigidaire/refrigerator
Frigidaire PLHS37EGSB1 Frigidaire/refrigerator
Frigidaire PLHS39EESS0 Frigidaire/refrigerator
Frigidaire PLHS39EESS1 Frigidaire/refrigerator
Frigidaire PLHS39EESS2 Frigidaire/refrigerator
Frigidaire PLHS39EESS3 Frigidaire/refrigerator
Frigidaire PLHS39EESS5 Frigidaire/refrigerator
Frigidaire PLHS39EESS6 Frigidaire/refrigerator
Frigidaire PLHS39EESS7 Frigidaire/refrigerator
Frigidaire PLHS39EESS9 Frigidaire/refrigerator
Frigidaire PLHS39EESSN Frigidaire/refrigerator
Frigidaire PLHS67EESB0 Frigidaire/refrigerator
Frigidaire PLHS67EESB3 Frigidaire/refrigerator
Frigidaire PLHS67EESB4 Frigidaire/refrigerator
Frigidaire PLHS67EESB5 Frigidaire/refrigerator
Frigidaire PLHS67EESB7 Frigidaire/refrigerator
Frigidaire PLHS67EESB8 Frigidaire/refrigerator
 PLHS67EESB9 FRIGIDAIRE/REFRIGERATOR
Frigidaire PLHS67EFSB0 Frigidaire/refrigerator
Frigidaire PLHS67EFSB1 Frigidaire/refrigerator
Frigidaire PLHS67EGSB0 Frigidaire/refrigerator
Frigidaire PLHS67EGSB1 Frigidaire/refrigerator
Frigidaire PLHS67EGSB2 Frigidaire/refrigerator
Frigidaire PLHS67EGSB3 Frigidaire/refrigerator
Frigidaire PLHS67EGSB5 Frigidaire/refrigerator
Frigidaire PLHS68EESB1 Frigidaire/refrigerator
Frigidaire PLHS68EESB2 Frigidaire/refrigerator
Frigidaire PLHS68EESB5 Frigidaire/refrigerator
Frigidaire PLHS68EESB6 Frigidaire/refrigerator
Frigidaire PLHS68EESB8 Frigidaire/refrigerator
Frigidaire PLHS68EESB9 Frigidaire/refrigerator
Frigidaire PLHS68EESBA Frigidaire/refrigerator
Frigidaire PLHS68EFSB0 Frigidaire/refrigerator
Frigidaire PLHS68EFSB1 Frigidaire/refrigerator
Frigidaire PLHS69EESS1 Frigidaire/refrigerator
Frigidaire PLHS69EESS2 Frigidaire/refrigerator
Frigidaire PLHS69EESS5 Frigidaire/refrigerator
Frigidaire PLHS69EESS7 Frigidaire/refrigerator
Frigidaire PLHS69EESS9 Frigidaire/refrigerator
Frigidaire PLHS69EESSN Frigidaire/refrigerator
Frigidaire PLHS69EFSS0 Frigidaire/refrigerator
Frigidaire PLHS69EFSS1 Frigidaire/refrigerator
Frigidaire PLHS69EFSS2 Frigidaire/refrigerator
Frigidaire PLHS69EGSS1 Frigidaire/refrigerator
Frigidaire PLHS69EGSS2 Frigidaire/refrigerator
Frigidaire PLHS69EGSS3 Frigidaire/refrigerator
Frigidaire PLHS69EGSS4 Frigidaire/refrigerator
Frigidaire PLHS69EGSS5 Frigidaire/refrigerator
Frigidaire PLHT189CSB0 Frigidaire/refrigerator
Frigidaire PLHT189CSB2 Frigidaire/refrigerator
Frigidaire PLHT189CSB4 Frigidaire/refrigerator
Frigidaire PLHT189CSB6 Frigidaire/refrigertor
Frigidaire PLHT189CSB8 Frigidaire/refrigerator
Frigidaire PLHT189CSBA Frigidaire/refrigerator
Frigidaire PLHT189CSBB Frigidaire/refrigerator
Frigidaire PLHT189CSBC Frigidaire/refrigerator
Frigidaire PLHT189CSBD Frigidaire/refrigerator
Frigidaire PLHT189CSBE Frigidaire/refrigerator
Frigidaire PLHT189CSBF Frigidaire/refrigerator
Frigidaire PLHT189CSK0 Frigidaire/refrigerator
Frigidaire PLHT189CSK2 Frigidaire/refrigerator
Frigidaire PLHT189CSK4 Frigidaire/refrigerator
Frigidaire PLHT189CSK6 Frigidaire/refrigertor
Frigidaire PLHT189CSK8 Frigidaire/refrigerator
Frigidaire PLHT189CSKA Frigidaire/refrigerator
Frigidaire PLHT189CSKB Frigidaire/refrigerator
Frigidaire PLHT189CSKC Frigidaire/refrigerator
Frigidaire PLHT189CSKD Frigidaire/refrigerator
Frigidaire PLHT189CSKE Frigidaire/refrigerator
  #2 (permalink)
Old 03-04-2009, 03:57 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Unplug the unit and order the compressor start device, AP4367355. You run capacitor is probably ok, just make sure you wire it in, in yours I think it just plugs into the start device.
__________________
  #3 (permalink)
Old 03-04-2009, 07:26 PM
Junior Member
Default
Well, I'll probably end up doing just that, but out of curiosity, why do you believe the capacitor is fine? I seem to recall reading somewhere that you should see a gradual increase in resistance when measuring a capacitor. Is that incorrect?
Also, any tricks you can recommend to unplug the wires from the relay?
Thanks again.
  #4 (permalink)
Old 03-05-2009, 01:29 AM
Senior Expert
APP Volunteer
Default
In my 23 years of service I have never seen an oil filled capacitor fail except for a few months ago i replaced a washer start capacitor that had blown literally. I don't think it was oil filled though.
I use a flat blade screwdriver to pry the spade terminals off.
__________________
  #5 (permalink)
Old 03-08-2009, 08:58 PM
Junior Member
Default
Well, the replacement relay arrived, and I installed it without too much trouble (had to splice in the wiring harness, which wasn't too bad, except I had to do the soldering on the floor, behind the fridge).
Anyway, bottom line is, the compressor is still not turning over
The capacitor isn't bulging or anything like that, so you're probably correct in that it's not the problem.
It seems to me that the problem may simply be that the compressor is locked up.
Any other ideas would be appreciated.
Otherwise, I'm ordering a new fridge.
  #6 (permalink)
Old 03-09-2009, 01:55 AM
Senior Expert
APP Volunteer
Default
If your run capacitor where shortd or open, the compressor would still start. It would just fail later. Even if your capacitor is bad it's academic, ie too late, your compressor start winding is bad.
Frigidair has had a lot of trouble with compressors failing, so you might want to bur a Whirlpool or Amana instead.
__________________
  #7 (permalink)
Old 03-24-2009, 10:15 AM
Junior Member
Redbone is on a distinguished road
Default
I have a 10 yo Amana doing exactly the same thing, thanks for the description. I replaced the Start/Overload relay but I suspect that the compressor is going bad. BTW, my Amana is just a re-branded Maytag.
ETA:
"Capacitor:
I tried checking the resistance of the capacitor. I read some resistance value for less than a second, then the meter reads no continuity and stays that way (I stopped after about 10 seconds). Does this mean I've got a bad capacitor, or am I doing something wrong with how I'm taking the measurement?"
That is EXACTLY what a good capacitor should do, providing that the +/- is hooked correctly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compressor Not turning off on defrost Thomo Refrigerator & Freezer Repair 0 12-23-2009 08:10 PM
New motherboard not turning on compressor or evaporator fan jamievbva Refrigerator & Freezer Repair 0 11-27-2009 02:55 PM
Dehumidifier compressor not turning on... Seanyboy Heating, Ventilation, and Air Conditioning (HVAC) 1 09-01-2009 12:38 PM
HELP compressor is not turning on RIP Refrigerator & Freezer Repair 11 10-15-2008 02:08 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
