Discuss
water will not despense
 in
Refrigerator & Freezer Repair
we moved our refrigerator yesterday to put down a new floor. we had to disconnect the water supply. when we
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water will not despense
  #1 (permalink)
Old 06-17-2011, 06:23 PM
Junior Member
tmeunier is on a distinguished road
Default water will not despense
Brand: Kenmore   Age: 5 - 10 years
we moved our refrigerator yesterday to put down a new floor. we had to disconnect the water supply. when we reinstalled and turned the water back on it would not despense water thru the door. we checked the shut off valve, checked for kinks in the tubing, replaced the inline filter. water is getting to the unit and going to the filter but does not seem to be going to the water despenser. I am still testing to see if going to ice maker. the door switch is working properly. Help, it seems like is should be something simple.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer stopped working, electrical arc or odor, & leaking water from water/ice line elmwood Refrigerator & Freezer Repair 1 10-10-2010 08:25 AM
Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water ugagrad04 Refrigerator & Freezer Repair 0 07-20-2010 06:43 PM
water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) david465 Refrigerator & Freezer Repair 4 03-11-2010 04:12 PM
GE Side by Side - water will not despense rhemshot Refrigerator & Freezer Repair 8 11-14-2009 01:58 PM
Ice will not despense from door Hacksawit Refrigerator & Freezer Repair 0 07-13-2009 12:10 PM
