Discuss
Ice maker wont make ice.
 in
Refrigerator & Freezer Repair
Whirlpool and other models. First thing to check is the MAIN shut off valve that the water supply line is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker wont make ice.
  #1 (permalink)
Old 06-15-2011, 04:25 PM
Junior Member
Tatersalad is on a distinguished road
Default Ice maker wont make ice.
Brand: -brand-   Age: Less than 1 year
First thing to check is the MAIN shut off valve that the water supply line is connected to. I know, you are getting water thru the door and no ice, or some water thru the door, sometimes, etc....Happened to me on my Whirlpool side by side and my neighbors.
Do this before buying, or tearing anything else apart.
1. Find the water shut off valve from the house water supply, open & close it a couple times, listen for water, etc.....try water thru the door, should be better.
2. Check the water supply opening inside the freezer that fills the icemaker to see if it is frozen. Unthaw with a hair dryer.
3. Unplug the refrig and plug it back in, ice maker will fill.
If you have a copper supply line, connected to your copper water pipe, screw it closed and reopen it.
Hope this will help someone, seems to be a common problem.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer wont make ice godfather86 Oven Repair (including Ranges and Cooktops) 3 03-01-2011 12:33 PM
make ice but wont dispense water or ice wbuchholz Refrigerator & Freezer Repair 0 02-12-2011 06:52 PM
Ice maker wont make ice Lanel08 Refrigerator & Freezer Repair 1 03-14-2009 10:10 AM
ice maker wont make ice Jonathan Burns Refrigerator & Freezer Repair 1 03-05-2009 05:37 PM
Ice Maker Wont Make Ice chefinthecity Refrigerator & Freezer Repair 1 12-12-2008 11:53 AM
