| » freezer working good frig not cold no frost on freezer coils |
A model number may help others help you.
You may have checked your coils just after a defrost cycle and that is why there was no frost. Since the freezer is cold there will be frost on the coils after a couple hours of run time. You do not have a defrost problem, for defrost to cause problems the coils must be iced/frosted over to the point that the fan cannot pull air through them. Just to be sure the freezer is cold enough measure the tem[perature, should be 0 to 5 degrees F. If OK Many units have a damper between the freezer and the fresh food side, it regulates tha amount of cold air entering the freskh food side. Perhaps it is not opening.
__________________
| Display Modes | |
| frig is warm, freezer cold w/frost build up | Veronica R | Refrigerator & Freezer Repair | 4 | 06-07-2011 01:36 AM |
| Whirlpool Frig-Freezer good/Frig warm | TD3 | Refrigerator & Freezer Repair | 5 | 12-18-2010 03:24 AM |
| Frost Build-Up in freezer (refrig & freezer not as Cold as usual) | boots1 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2009 03:08 AM |
| Freezer cold, evaporator fan not working, frost build up in freezer | heretolearn2 | Refrigerator & Freezer Repair | 3 | 05-28-2008 02:45 PM |
| Freezer has frost and cold/frig is not very cold | DinATL | Refrigerator & Freezer Repair | 1 | 09-14-2007 07:38 PM |
