hamlet
hi
can anyone tell me where is the fuse for the evaporator fan motor,on this model. i cheaked for current first.but when working to take the fan out one wire grounded (shorted) , and now there is no current now. |
hamlet or romeo
ftp://ftp.electrolux-na.com/ProdInfo.../240389616.pdf
Hamlet, here's a link for the wiring diagram to your model (hopefully it works).. After seeing the diagram I'm convinced I need some more schoolin' on troubleshooting these adaptive defrost controls... You may have fried this control when the wire shorted going to the motor... Call APP for assistance with this repair... Some part numbers are included at this link... And remember to unplug the fridge next time you're taking wiring loose, just so YOU don't get fried and end up like Romeo & Juliet... cheers, kooler |
Are you getting power to the fridge? There is no fuse. If there is no power at the plug, check the house circuit breaker. Post back with details...
with the power on and the thermostat shut off there should be no power to the fan unless your outlet plug has reverse polarity..
| All times are GMT -7. The time now is 12:42 PM. |
