Discuss
Whirlpool Roper: freezer/refrig not cold enough
 in
Refrigerator & Freezer Repair
My Roper refirgerator will not cool enough. The icecream turns to milkshake, and the frige side is just barely cold
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Roper: freezer/refrig not cold enough
  #1 (permalink)
Old 06-12-2011, 09:12 AM
Junior Member
Jzerb is on a distinguished road
Default Whirlpool Roper: freezer/refrig not cold enough
Brand: Roper   Age: 5 - 10 years
My Roper refirgerator will not cool enough. The icecream turns to milkshake, and the frige side is just barely cold enough. I here the unit cycling on and off in what seems to be a normal cycle. I removed the back paper panel and the what I believe is the compressor (Black round bulb) is very hot to touch. The coils underneath were clean. The bar inbetween the refrig and freezer is extemely hot. Now I have not ever disasembled a unit but I have been extemely successful in everything I have tried so I am willing to give this a shot. How do I disasemble the frig to look at the internal coils? Could this be just a thermastat? Where is the thermastat? The back of the fridge has a large metal galvanized sheet. Can I remove this? I just want to find a few directions to take. In the meantime I will continue to do troubleshooting with possible attempts.
The model number is RS25AGXNQ01, serial number 53745366
  #2 (permalink)
Old 06-13-2011, 05:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL RS25AGXNQ01 REFRIGERATOR | AppliancePartsPros.com
Was the condenser/compressor fan running?
You may have two problems.
The hot divider usually means that the condenser coils are not getting rid of the heat properly. You have checked the condenser coils hence the fan question, also check that the vents on the front kick plate are clean.
That the unit is cycling but the freezer is not getting cold enough points towards a thermostat (Item 9 in Section 11) problem.
The unit thinks that it is hitting the set-point temperature and is therefore cycling when it fact the temperature is too high, I think.
I would check the temperature in the freezer, it should be 0 to 5 degrees F.
Here is a good link that should help with your troubleshooting
http://www.applianceaid.com/frig.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool - Freezer icy but Refrig not too cold Rav4L Refrigerator & Freezer Repair 5 06-16-2011 03:52 AM
Outside Refrig/Freezer in Garage does not stay cold in cold weather verno1 Refrigerator & Freezer Repair 2 12-14-2010 12:07 PM
Whirlpool refrig/freezer freezer cold refig not resha Refrigerator & Freezer Repair 1 12-07-2009 08:38 PM
Whirlpool refrig/freezer freezer cold refig not resha Refrigerator & Freezer Repair 0 12-05-2009 08:50 AM
Frost Build-Up in freezer (refrig & freezer not as Cold as usual) boots1 Oven Repair (including Ranges and Cooktops) 1 01-18-2009 03:08 AM
