Discuss
Freezer not getting cold enough
 in
Refrigerator & Freezer Repair
Denman, the adaptive defrost board came yesterday and I attempted to pu it in ... but there are just a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer not getting cold enough
  #11 (permalink)
Old 06-15-2011, 04:06 AM
Junior Member
jerry.kegelman@nasa.gov is on a distinguished road
Default
Denman, the adaptive defrost board came yesterday and I attempted to pu it in ... but there are just a few differences between the old and the new. It has obviously been redesegned, with about 90% of the connections being a direct and obvious fit, however there are a few minor thigs that at this point, I just guessing, for example, there is no Pink wire at all and the one from the old unit has a few extra things on it. there are a few others, but is there a manual that says what to switch and how to make up the differences? - Jerry K
  #12 (permalink)
Old 06-15-2011, 04:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I could not find any info but I will post in the tech section to see if someone else has the info you need.
__________________
  #13 (permalink)
Old 06-15-2011, 05:02 AM
Junior Member
Default
Thanks ... I'm looking over the schemstics carefully to see if there's an obvious thing that needs to be brough tover from what's there already ... but this pesky day job keeps getting in the way! - Jerry K
  #14 (permalink)
Old 06-15-2011, 12:15 PM
Junior Member
Default
Denman ... any luck yet? The schematics you sent don't exactly match the replacement "Adaptive Defrost Circuit" I received, but I should be able to see what's different and rig it up to work ... wish me luck! - Jerry K
  #15 (permalink)
Old 06-16-2011, 02:44 AM
Senior Expert
APP Volunteer
Default
Good luck
Hopefully when you go to install it there will be no problems and everything will fall into place.
I did post in the Tech Section with a link to this thread so any reply will probably come directly here.
So far 4 people have looked at the post but no reply.
__________________
  #16 (permalink)
Old 06-16-2011, 05:10 AM
Junior Member
Default
Well, Its Kinda-sorta Working, but not like it used to. I had (and still have) some difficulty making direct crossover connections. My suspicions started when the damper motor that drives the baffle dore between freezer and fridge had different color wires on it (red with black stripe and lite blue and nor gray and lite blue) then there was only one switch connection for the damper motor and not two, so I', left with leaving one or the other connected to the new adaptive defrost box, and I need to leave the other still connected to the old wire harness ... but which one? My fix so far has been to just leave the wire off the damper motor, stopping it mostly closed. and I might fuss with it leaving it more or less open until the temps are OK, but this is somewhat of a Rube Goldberg fix and not exactly right. and as a certified NASA Nerd, I want it right!!!, so some further guidance is needed! (is it possible they sent me the qwrong Adabtive Defrost board?)
- Jerry K
  #17 (permalink)
Old 06-17-2011, 03:02 AM
Senior Expert
APP Volunteer
Default
I doubt it is the wrong board.
It is supposed to be a universal kit and probably fits lots of older units.
I just wish I could find some info on it, as it is unusual that they do not include an install sheet.
I am off to the cottage for a few days so will be unavailable.
Perhaps try a new post about install help for this kit perhaps then someone will jump in with some fresh info.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/freezer not staying cold, then too cold wendymay Refrigerator & Freezer Repair 0 03-31-2011 06:40 PM
Outside Refrig/Freezer in Garage does not stay cold in cold weather verno1 Refrigerator & Freezer Repair 2 12-14-2010 12:07 PM
Freezer cold but not freezing, Refrigerator cool but not cold sixboyzdad Refrigerator & Freezer Repair 1 06-09-2010 09:00 PM
Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough tvGhouse Refrigerator & Freezer Repair 0 02-25-2009 02:50 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
