| » Ice Maker |
Model Number: ksrg25fkssk15 Brand: Kitchen Aid Age: 1 - 5 years
Ice maker stopped making ice. Replaced the solenoid, which didn't work, but in the process remedied a low water flow problem by replacing the saddle-type supply valve. Still no ice.
This has the "optical" sensor, and when the door is open, the status LED gives two flashes, a longer pause, two flashes, etc. When I press in the paddle switch on the left side, the LED is on steadily. The fill tube at the top is not itself frozen, but I can't tell if there is freezing above it. Any thoughts? Ads By Google Related Models |
Can you disconnect the water line the goes to the ice maker from the water valve in back of the refrigerator and blow air through it?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Quote:
If you can not blow air through it then that is the problem.
__________________
Sounds good, let us know.
__________________
I did what you suggested, and it seemed that, although it was difficult, some air did move through the tube. (I tried the other line first, which is slightly larger diameter, and no air moved through it, so I assume that was the line for the water dispenser.
Any further thoughts? |
Perform the ice maker troubleshooting as described in one of our previous posts: Water to ice maker quit working and post the results.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| New ice maker installed but no water running to ice maker | corona32guiness | Refrigerator & Freezer Repair | 0 | 01-06-2010 05:14 PM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:27 AM |
| Ice Maker water is dispensing into the bin instead of into the cube maker | jghani | Refrigerator & Freezer Repair | 0 | 09-12-2009 10:20 AM |
| GE tube ice maker freezing but ice maker works | dhayden | Refrigerator & Freezer Repair | 1 | 09-05-2009 08:54 AM |
| Replaced Ice Maker and noid and still no water to ice maker | darrewhite | Refrigerator & Freezer Repair | 0 | 05-17-2009 06:34 AM |
