Discuss
defrost timer
 in
Refrigerator & Freezer Repair
Hello, My freezer is working but my refregirator gets warm. I tried to locate the defrost timer to test it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » defrost timer
  #1 (permalink)
Old 06-07-2011, 02:47 PM
Junior Member
tarikkabbaj is on a distinguished road
Default defrost timer
Model Number: gs5shaxnb00   Brand: Whirlpool   Age: 1 - 5 years
Hello,
My freezer is working but my refregirator gets warm. I tried to locate the defrost timer to test it but I could not find it. please advise! thanks,
Tarik
Ads By Google
Related Models
Whirlpool GS5SHAXNB00 Refrigerator
Whirlpool GS5SHAXNB01 Refrigerator
Whirlpool GS5SHAXNL00 Refrigerator
Whirlpool GS5SHAXNL01 Refrigerator
Whirlpool GS5SHAXNQ00 Refrigerator
Whirlpool GS5SHAXNQ01 Refrigerator
Whirlpool GS5SHAXNS00 Refrigerator
Whirlpool GS5SHAXNS01 Refrigerator
Whirlpool GS5SHAXNT00 Refrigerator
Whirlpool GS5SHAXNT01 Refrigerator
Whirlpool GS5SHAXSA00 Refrigerator
Whirlpool GS5SHAXSA01 Refrigerator
Whirlpool GS5SHAXSB00 Refrigerator
Whirlpool GS5SHAXSB01 Refrigerator
Whirlpool GS5SHAXSL00 Refrigerator
Whirlpool GS5SHAXSL01 Refrigerator
Whirlpool GS5SHAXSQ00 Refrigerator
Whirlpool GS5SHAXSQ01 Refrigerator
Whirlpool GS5SHAXTB00 Refrigerator
Whirlpool GS5SHAXTB01 Refrigerator
Whirlpool GS5SHAXTL00 Refrigerator
Whirlpool GS5SHAXTL01 Refrigerator
Whirlpool GS5SHAXTQ00 Refrigerator
Whirlpool GS5SHAXTQ01 Refrigerator
Whirlpool GS5SHAXTS00 Refrigerator
Whirlpool GS5SHAXTS01 Refrigerator
Whirlpool GS5SHGXKB00
Whirlpool GS5SHGXKQ00
Whirlpool GS5SHGXKS00
Whirlpool GS5SHGXKT00
Whirlpool GS5SHGXLB00
Whirlpool GS5SHGXLB01
Whirlpool GS5SHGXLL00
Whirlpool GS5SHGXLL01
Whirlpool GS5SHGXLQ00
Whirlpool GS5SHGXLQ01
Whirlpool GS5SHGXLS00
Whirlpool GS5SHGXLS01
Whirlpool GS5SHGXLT00
Whirlpool GS5SHGXLT01
Whirlpool GS6NBEXRA00 Refrigerator
Whirlpool GS6NBEXRA01 Refrigerator
Whirlpool GS6NBEXRA02 Refrigerator
Whirlpool GS6NBEXRB00 Refrigerator
Whirlpool GS6NBEXRB01 Refrigerator
Whirlpool GS6NBEXRB02 Refrigerator
Whirlpool GS6NBEXRL00 Refrigerator
Whirlpool GS6NBEXRL01 Refrigerator
Whirlpool GS6NBEXRL02 Refrigerator
Whirlpool GS6NBEXRQ00 Refrigerator
Whirlpool GS6NBEXRQ01 Refrigerator
Whirlpool GS6NBEXRQ02 Refrigerator
Whirlpool GS6NBEXRS00 Refrigerator
Whirlpool GS6NBEXRS01 Refrigerator
Whirlpool GS6NBEXRS02 Refrigerator
Whirlpool GS6NBEXRT00 Refrigerator
Whirlpool GS6NBEXRT01 Refrigerator
Whirlpool GS6NBEXRT02 Refrigerator
Whirlpool GS6NBEXRY00 Refrigerator
Whirlpool GS6NBEXRY01 Refrigerator
Whirlpool GS6NBEXRY02 Refrigerator
Whirlpool GS6NVEXSA00 Refrigerator
Whirlpool GS6NVEXSA01 Refrigerator
Whirlpool GS6NVEXSB00 Refrigerator
Whirlpool GS6NVEXSB01 Refrigerator
Whirlpool GS6NVEXSL00 Refrigerator
Whirlpool GS6NVEXSL01 Refrigerator
Whirlpool GS6NVEXSQ00 Refrigerator
Whirlpool GS6NVEXSQ01 Refrigerator
Whirlpool GS6NVEXSS00 Refrigerator
Whirlpool GS6NVEXSS01 Refrigerator
Whirlpool GS6NVEXST00 Refrigerator
Whirlpool GS6NVEXST01 Refrigerator
Whirlpool GS6NVEXSY00 Refrigerator
Whirlpool GS6NVEXSY01 Refrigerator
Whirlpool GS6NVEXVB00 Refrigerator
Whirlpool GS6NVEXVL00 Refrigerator
Whirlpool GS6NVEXVQ00 Refrigerator
Whirlpool GS6NVEXVS00 Refrigerator
Whirlpool GS6SHANLB10
Whirlpool GS6SHANLQ10
Whirlpool GS6SHAXKB01
Whirlpool GS6SHAXKB02
Whirlpool GS6SHAXKQ01
Whirlpool GS6SHAXKQ02
Whirlpool GS6SHAXKS01
Whirlpool GS6SHAXKS02
Whirlpool GS6SHAXKT01
Whirlpool GS6SHAXKT02
Whirlpool GS6SHAXLB01
Whirlpool GS6SHAXLB02
Whirlpool GS6SHAXLB03 Refrigerator
Whirlpool GS6SHAXLL01
Whirlpool GS6SHAXLL02
Whirlpool GS6SHAXLL03 Refrigerator
Whirlpool GS6SHAXLQ01
Whirlpool GS6SHAXLQ02
Whirlpool GS6SHAXLQ03 Refrigerator
Whirlpool GS6SHAXLS01
Whirlpool GS6SHAXLS02
Whirlpool GS6SHAXLS03 Refrigerator
Whirlpool GS6SHAXLT01
Whirlpool GS6SHAXLT02
Whirlpool GS6SHAXLT03 Refrigerator
Whirlpool GS6SHAXMB00 Refrigerator
Whirlpool GS6SHAXML00 Refrigerator
Whirlpool GS6SHAXMQ00 Refrigerator
Whirlpool GS6SHAXMS00 Refrigerator
Whirlpool GS6SHAXMT00 Refrigerator
Whirlpool GS6SHEXMB00 Refrigerator
Whirlpool GS6SHEXMB01 Refrigerator
Whirlpool GS6SHEXML00 Refrigerator
Whirlpool GS6SHEXML01 Refrigerator
Whirlpool GS6SHEXMQ00 Refrigerator
Whirlpool GS6SHEXMQ01 Refrigerator
Whirlpool GS6SHEXMS00 Refrigerator
Whirlpool GS6SHEXMS01 Refrigerator
Whirlpool GS6SHEXMT00 Refrigerator
Whirlpool GS6SHEXMT01 Refrigerator
Whirlpool GS6SHEXNB00 Refrigerator
  #2 (permalink)
Old 06-07-2011, 05:32 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL GS5SHAXNB00 REFRIGERATOR | AppliancePartsPros.com
See the attachment for the tech sheet
You do not have a defrost timer, defrost is controlled by the main control board (Item 18 in Section 11).
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, see the tech sheet when the fans and compressor turn off you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 11) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. It seems it is missing from the parts breakdown but there will be one clipped to the evaporator coils.
If both the above are OK then odds are the control board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
__________________
  #3 (permalink)
Old 06-07-2011, 08:09 PM
Junior Member
Default
Thank you Denman, I will need to replace the electric board. Is it easy to change?and what is the process? thanks again for you advise
Tarik,
  #4 (permalink)
Old 06-08-2011, 04:34 AM
Senior Expert
APP Volunteer
Default
Should not be that difficult though I have never done one.
Just be sure to unplug the unit.
Also touch a ground before handling the board to get rid of any static electricity your body may be holding.
If you has copper plumbing pipes then one of them will do.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Does my Maytag have a defrost timer or adaptive defrost control? Where is it? Momto8 Refrigerator & Freezer Repair 13 06-18-2012 06:37 PM
new defrost timer wont come out of defrost jfmorton Refrigerator & Freezer Repair 1 04-01-2010 01:02 PM
I still have froze in the freezer after changing defrost timer & bi-metal defrost matteson Refrigerator & Freezer Repair 0 12-29-2009 06:25 PM
Defrost timer only works in defrost cycle george10 Refrigerator & Freezer Repair 2 07-18-2009 06:15 PM
Defrost Timer AGAIN Karen S Refrigerator & Freezer Repair 5 01-05-2008 06:12 AM
