drfransen
#1 Posted : Sunday, February 22, 2009 12:53:28 AM(UTC)
drfransen
My problem is like all the others in this thread, the freezer is fine, but the refrig is not. The defrost system is working as it should, no frost/ice buildup on the back panel, but I took off the back panel anyway to observe the frost/defrost cycle, which is working fine - so I assume it is operating properly. Also I put and HVAC thermostat in the freezer compartment, it read 30 degrees in less than 15 minutes.
I've searched and searched, probably missed it somewhere, but how do I test the evaporator fan? Should it be running all the time? I don't want to spend time and money to troubleshoot by multiple parts swapping.
Thanks for any assistance you can give.
Darrell
#2 Posted : Sunday, February 22, 2009 3:15:03 AM(UTC)
Model RT14BKXKQ05
Here is the wiring
https://www.servicematters.com/d...0Sheet%20-%202265209.pdf
Yes it should be on when ever the compressor is on.
They are wired in parallel.
Could check it's resistance with a meter. Not sure what it should be but it should not be an open.
Could also hook it up to a line cord and see if it runs
drfransen
#3 Posted : Monday, February 23, 2009 2:23:49 AM(UTC)
drfransen
Originally Posted by: denman Go to Quoted Post
Model RT14BKXKQ05
Here is the wiring
denman,
Thanks for the quick response. I removed the fan, hooked it up to 110v - it didn't work, so I have ordered a replacement. Thanks for your assistance. I'll post another response when I get the new fan installed.
Darrell
drfransen
#4 Posted : Thursday, February 26, 2009 1:05:01 AM(UTC)
drfransen
:D Thanks to denman who gave me the idea.... I got the new fan yesterday, put it in and plugged it in. The fridge is nice and cold this morning. Saved the cost of a service call. Thany you, thany you.
Darrell
