| » door water Frigidaire |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: frs23h7cw2 Brand: Frigidaire Age: 1 - 5 years
This problem was that it would work off and on. It seemed to help if I moved the unit. Now it does not work at all. I have disconnected the line from the valve and it is clear. The ice maker is still working. Is there something else that could cause it besides the water valve?
Dean |
Hi Dean
The first thing I would check if the power is coming to the water valve when you push the lever on the door. If there is no power then the problem is a bad switch in the water dispenser on the door. If there is power then the problem is a bad water valve. Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. |
Keep me updated, please.
__________________
When I had this apart and put it back together, I put vaseline on the electric connections and then in about two days later the unit started working and has been working since. Now I don't know if I should replace the water valve. I think I'll wait a while and see if it keeps working.
Dean |
| Display Modes | |
| Frigidaire Front Load New Door Lock | kcchadmac | Washer Repair | 1 | 12-16-2007 06:38 PM |
| Frigidaire ice door | alanbr | Refrigerator & Freezer Repair | 1 | 10-24-2007 02:45 AM |
| water draining and detergent door | Connie | Dishwasher Repair | 1 | 10-22-2007 02:46 AM |
| Frigidaire Ice Maker not getting water & not working | Salpal | Refrigerator & Freezer Repair | 1 | 09-27-2007 07:01 AM |
| water dispensing from door on it's own | jenofflorida@aol.com | Refrigerator & Freezer Repair | 0 | 08-13-2007 12:20 PM |
