The relay just keeps pulsing(energizing). I was looking for the schematics for it.The top right connecter on the c.board is my querry.When I disconnect it,the clicking stops and it stays in defrost mode.Can anyone answer what the plug connects to? It holds 2 White wires(one larger gauge),one Grey,and 2 Blue with white stripe.Are these for sensors?
The schematic is usually behind the control panel. To fix, I would replace the motherboard in the back AP4436216 and also the evaporator thermistor, a thin white item clipped to the top of the evaporator.
