Hello, My 8 year old Samsung ice maker stopped functioning. It was not turning to harvest and so the water would hit the formed ice and flood the freezer and then out of the fridge. I purchased the replacement ice maker and installed it AP4172188 (DA97-00258C) ASSY ICE MAKER and all went well. Tested the harvest function after the installation and it was fine.
This morning same water issue again. Tested the ice maker so that's not the issue since it's turning, but the ice will not dump, causing new water to go on top and flood the freezer bin.
Any idea what is going on? Thanks in advance for tips and help.
