At first the defrost cycle would not happen, so I replaced all three thermistors. When I plugged in the power I hear a weird click and nothing turns on while the green light in the water dispenser blinks. I noticed that a resistor in the control board was burnt so I replaced the control board. Still no luck, everything is the same (When I plugged in the power I hear a weird click and nothing turns on while the green light in the water dispenser blinks). But when I unplug the harness that powers the evaporator fan motor and one of the thermistors everything kicks on and the coils start to get cold.
