Discuss
refrigerator
 in
Refrigerator & Freezer Repair
water leaking once in a while from refrigerator or freezer??removed water filter and shut off water to both. still leaks.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator
  #1 (permalink)
Old 06-02-2011, 01:10 PM
Junior Member
delightful is on a distinguished road
Default refrigerator
Brand: Whirlpool   Age: 1 - 5 years
water leaking once in a while from refrigerator or freezer??removed water filter and shut off water to both. still leaks. help!!!
donna yennir
dyennie@msn.com
Ads By Google
  #2 (permalink)
Old 06-03-2011, 04:29 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Could be that the water is from the defrost.
Check that the drain tube down to the drip tray under the unit is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tral after you are done.
Be sure to unplug the unit while doing this.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm 808BigShorty Refrigerator & Freezer Repair 2 02-23-2011 01:04 PM
refrigerator making loud revving engine noise and now feels warm in refrigerator part tallulah Refrigerator & Freezer Repair 0 02-06-2011 07:15 AM
Moved refrigerator, freezer fine but refrigerator is too warm tigerjim Refrigerator & Freezer Repair 1 06-09-2010 10:59 AM
GE Profile refrigerator-warm freezer & refrigerator ykim4492 Refrigerator & Freezer Repair 2 02-14-2010 05:52 PM
amana refrigerator not frezzing and refrigerator not cooling didhebiteyou Refrigerator & Freezer Repair 0 08-09-2009 09:43 AM
