Discuss
freezer leaking water
 in
Refrigerator & Freezer Repair
I just noticed a bit of water emenating from under my chest freezer. there is nothing else around that area
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer leaking water
  #1 (permalink)
Old 02-17-2009, 08:38 PM
glenross glenross is offline
Junior Member
glenross is on a distinguished road
Default freezer leaking water
Model Number: 21c   Brand: -other-   Age: More than 10 years
I just noticed a bit of water emenating from under my chest freezer. there is nothing else around that area to explain the water. so far the freezer appears normal ,with no loss of cooling and the compressor does not appear to be running all the time , but I would like to prepare myself to preserve all the contents if it becomes necessary..would these symptoms indicate that a condenser coil has a leak?
Related Models
Amana 21C3MS Room Air Conditioner
Amana 21C3MV Room Air Conditioner
Amana 21C3MY Room Air Conditioner
Amana 21C3SS Room Air Conditioner
Amana 21C3Y Room Air Conditioner
Amana 21C5V Room Air Conditioner
Amana 21C5W Room Air Conditioner
Amana 21C5Y Room Air Conditioner
Frigidaire 21KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 21KEMAWAD3-23 Tap(v2) / Electric Range
Frigidaire 21KEMAWAP3 Tap(v1)
Frigidaire 21KEMAWAP4 Tap(v2)
Frigidaire 21KEMAWAP5 Tap(v3)
Frigidaire 21KGMAWAN4 Tap(v1) / Gas Range
Frigidaire 21KGMAWAN4-23 Tap(v2) / Gas Range
Frigidaire 21KGMAWAN5 Tap(v1) / Gas Range
Frigidaire 21KGMAWAN5-66 Tap(v2) / Gas Range
Frigidaire 21KGMAWAN6 Tap(v3) / Gas Range
Frigidaire 21KGMAWAN6-66 Tap(v4) / Gas Range
Frigidaire 21KPMAWAN4 Tap(v1) / Gas Range
Frigidaire 21KPMAWAN4-32 Tap(v2) / Gas Range
Frigidaire 21KPMAWAN5 Tap(v3) / Gas Range
Frigidaire 21KPMAWAN5-32 Tap(v4) / Gas Range
Frigidaire 21KPMAWAN6 Tap(v5) / Gas Range
Frigidaire 21KPMAWAN6-32 Tap(v6) / Gas Range
Frigidaire 21KPMAWAN7 Tap(v1) / Gas Range
Frigidaire 21KPMAWAN7-32 Tap(v2) / Gas Range
Frigidaire 21KPMAWAN8 Tap(v3) / Gas Range
Frigidaire 21KPMAWAN8-32 Tap(v4) / Gas Range
Amana 21M23PA Room Air Conditioner
Amana 21QZ33RB Room Air Conditioner
Amana 21QZ33RC Room Air Conditioner
Amana 21QZ33RC1 Room Air Conditioner
Amana 220-3SPK Room Air Conditioner
Hoover 2200 Frigidaire/refrigerator
Jenn-Air 22001 Surface Unit - Ddraft Ele
Hoover 2201 Frigidaire/refrigerator
Hoover 2204 Frigidaire/refrigerator
Whirlpool 2204W0A
Whirlpool 2204W1A
Whirlpool 2204W2A
Whirlpool 2204^0A
Whirlpool 2204^1A
Whirlpool 2204^2A
Amana 2208.100 Commercial Microwaves
Amana 2208.101 Commercial Microwaves
Amana 2208.A Commercial Microwaves
Hoover 2210
Amana 2210.000 Mwave - Family Size (60 Hz)
Jenn-Air 22112 Surface Unit - Ddraft Ele
Jenn-Air 22113 Surface Unit - Ddraft Ele
Jenn-Air 22114 Surface Unit - Ddraft Ele
Jenn-Air 22115 Surface Unit - Ddraft Ele
Jenn-Air 22116 Surface Unit - Ddraft Ele
Whirlpool 2212W0A
Whirlpool 2212W1A
Whirlpool 2212Z1A
Whirlpool 2212^0A
Whirlpool 2212^1A
Whirlpool 2214W0A
Whirlpool 2214W1A
Whirlpool 2214W2A
Whirlpool 2214^0A
Whirlpool 2214^1A
Whirlpool 2214^2A
Amana 2215S Room Air Conditioner
Whirlpool 2222W00
Whirlpool 2222W1A
Whirlpool 2222^00
Whirlpool 2222^1A
Whirlpool 2222^2A
Whirlpool 2224W0A
Whirlpool 2224W1A
Whirlpool 2224^0A
Whirlpool 2224^1A
Whirlpool 2228W00
Whirlpool 2228W10
Whirlpool 2228W20
Whirlpool 2228W30
Whirlpool 2228W40
Whirlpool 2228^00
Whirlpool 2228^10
Whirlpool 2228^20
Whirlpool 2228^30
Whirlpool 2228^40
Jenn-Air 22305 Surface Unit - Ddraft Ele
Whirlpool 2233W0A
Whirlpool 2233Z1A
Whirlpool 2233^0A
Whirlpool 2233^1A
Amana 2234.000 Mwave - Family Size (60 Hz)
Whirlpool 2234W0A
Whirlpool 2234W1A
Whirlpool 2234W2A
Whirlpool 2234^0A
Whirlpool 2234^1A
Whirlpool 2234^2A
Amana 2236.100 Commercial Microwaves
Amana 2236.101 Commercial Microwaves
Amana 2237.A Mwave - Family Size (60 Hz)
Amana 2238.000 Mwave - Family Size (60 Hz)
Amana 2238.001 Mwave - Family Size (60 Hz)
General Electric 22388L0 Electric range
General Electric 22388W0 Electric range
Whirlpool 2238W00
Whirlpool 2238W10
Whirlpool 2238W20
Whirlpool 2238^00
Whirlpool 2238^10
Whirlpool 2238^20
Amana 2239.A Mwave - Family Size (60 Hz)
Amana 2240.000 Mwave - Family Size (60 Hz)
Jenn-Air 22401 Surface Unit - Ddraft Ele
Jenn-Air 22402 Surf Cont Panel Unit - Ddft Ele
Jenn-Air 22403 Surf Cont Panel Unit - Ddft Ele
  #2 (permalink)
Old 02-18-2009, 04:05 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
A brand and a complete model number would help.
21C just brings up Air Conditioners.
Here is some help on finding it
Model Number Locator
Also is the unit frost free.
__________________
  #3 (permalink)
Old 02-18-2009, 05:43 AM
Junior Member
Default
this freezer is 49 years old . made by woods in canada , it is not frost free. is 22 cubic ft capacity. I did not attempt provide that because the question , i felt was pretty general to a refrigeration problem. what i expect is that the freon is leaking slowly , causing condensation in the insulation that is dripping out on to the floor.
do you think i am right? Thankyou for your response.
Don
  #4 (permalink)
Old 02-18-2009, 06:35 AM
Senior Expert
APP Volunteer
Default
I doubt it is a freon leak.
By now you would have a low freon situation and the unit would run continuously.
More likely either the compressor is getting close to the end of its life or an orifice in the sealed system is clogging up.
See the below link re: Frosted up suction line
Another thing to check is the liner perhaps it has a crack.
Defrosting it may help
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice in bottom of freezer, Leaking water duoduo Refrigerator & Freezer Repair 0 01-27-2009 04:53 AM
Leaking water in freezer compartment stressman4 Refrigerator & Freezer Repair 1 01-24-2009 08:49 PM
water leaking under freezer rbialowas Refrigerator & Freezer Repair 3 05-12-2008 09:56 AM
Amana leaking water from freezer haight78 Refrigerator & Freezer Repair 0 05-12-2008 08:29 AM
Chest freezer leaking water larena Refrigerator & Freezer Repair 2 07-30-2007 12:45 AM
