my display panel lost power-I ordered another plugged it in still no good-I am seeing high resistence grounds and poss shorts when I go across the harness alone without the display plugged into it-no ac or low voltage noticeable on my meter--where can I ck next-thanks
Originally Posted by: 1242 my display panel lost power-I ordered another plugged it in still no good-I am seeing high resistence grounds and poss shorts when I go across the harness alone without the display plugged into it-no ac or low voltage noticeable on my meter--where can I ck next-thanks 1242, Your first check, should have been at the wire harness connection, and wiring at the freezer door hinge assembly. loose connections or damaged wires could create your problem and the readings you recieved on your meter. From there, I would have to start considderring a prolem with the "mother board", main control board on the back of the fridge. The board seems to be the "weak link" on this style refridgerator. Part number: AP4436216
We hope this is helpful, and gets you where you need to be. Good Luck, :) :) :)
