Register | FAQ's | New Posts | Today's Posts | Extras |
» not cold enough |
![]() Model Number: SXD22S2W Brand: Amana Age: More than 10 years
![]() the is a side by side that is 15 years old. I can hear it running but it is not cooling very well. The ice maker is not making ice. The lower area of freezer is colder than upper area. The refrigerator seems to not be as cool either. repair or replace? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Here are your parts
Replacement parts for SXD22S2W models | AppliancePartsPros.com The lower area of freezer is colder than upper area. Is the evaporator fan in the freezer running? If not then a temperature gradient in the freezer will happen as the air is not circulating. Check that the vent (Item 5 in Section 2) is clear in both compartments as it can impede air circulation. repair or replace? Cannot say as it depends on what is wrong with the unit.
__________________
![]() Quote:
It may be as simple as cleaning the condenser coil, and the area around the fridge, or maybe a slow running evaporator fan. To check the condenser coil, you'll need to remove the front grill, and use a vacuum to clear any debris that has accumulated on all the coils, be careful, the fins can be sharp. To check the evaporator fan, open the freezer door, you should be able to feel the air blowing towards you, in the area of the top shelf. and also check the back wall of the freezer compartment, for frost or ice build up on the wall, indicates a possible defrost problem. Also check and make sure the doors are closing and sealling, and that articles on all the shelves in both compartments are not hanging over the shelves or against any of the walls, restricting the air flow. Do these checks , repairs, give it a day or 2 to see if there's any improvement and we can go from there. Good Luck, ![]() ![]() ![]()
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
![]() Quote:
Doesn't seem like there is any air blowing at all anywhere. loweerr area of fridge still seems somewhat cold but upper areas not |
![]() Quote:
You did check and clean the condenser coil, Cold air drops, hot air rises, so it will be cooler in the bottom, OK, so when you opened the freezer door there was no frost or ice on the back wall, and you could not hear or feel the air from the evaporator fan, correct ? We'd have to presume, the evaporator fan has stopped running, and is not circulating the cold air. Part number: AP4246892 ![]() ![]() ![]() ![]() ![]() ![]()
__________________
![]() Quote:
Give it a couple of hours, and recheck for a better cooling process and if the evaporator fan is running and moving air. ![]() ![]() ![]()
__________________
![]() Quote:
by not cleaning the underneath of the fridge have I made something fail? Like the evap fan? |
![]() Quote:
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Outside Refrig/Freezer in Garage does not stay cold in cold weather | verno1 | Refrigerator & Freezer Repair | 2 | 12-14-2010 12:07 PM |
Cold/Cold, Warm/Colc and Hot/cold buttons do not trigger the rise cycles | ralphdisimone@gmail.com | Washer Repair | 5 | 10-18-2010 07:37 AM |
Cold/Cold, Warm/Cold and Hot/Cold Button Settings do not trigger the Rinse cycles | ralphdisimone@gmail.com | Washer Repair | 1 | 10-12-2010 02:55 PM |
no cold water on cold/cold cycle | rpbmd | Washer Repair | 1 | 08-28-2009 10:04 AM |
Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough | tvGhouse | Refrigerator & Freezer Repair | 0 | 02-25-2009 02:50 PM |
