dalesi
#1 Posted : Tuesday, May 31, 2011 6:54:59 PM(UTC)
dalesi
Does the front panel that surrounds the water and ice dispenser come off? We need to make a repair to the water dispenser.
Joe / APP Team
#2 Posted : Wednesday, June 1, 2011 8:24:43 AM(UTC)
Joe / APP Team
Dalesi,
Yes, the dispenser facade is removable.
This information should get you through the repair.
It will require a flat blade screwdriver, caution,and a wrag or tape, so you don't damage the freezer door.
[FONT=Arial.Bold.Italic050]SERVICING THE ICE AND WATER DISPENSER[/FONT]
[FONT=Times.New.Roman050]The new ice and water dispenser is a simplified design, using half the number of parts as the previous design. Since the new dispenser is foamed-in. the freezer door, it cannot be removed as an assembly, however it can be easily serviced. Following are the steps for disassembly[/FONT]
[FONT=Arial045.813][FONT=Arial045.813]1. Unplug the refrigerator power cord.[/FONT]
[FONT=Arial045.813]2. Remove the overflow grille from the housing.[/FONT]
[FONT=Arial045.813]3. Unsnap front cover at the bottom of the housing,using the flatblade screwdriver to twist or pry out at the slots molded into the bottom edge of the facade.[/FONT]
[/FONT][FONT=Arial.Italic045.813]
[/FONT][FONT=Arial045.813][FONT=Arial045.813]4. Disconnect the front cover switch harness connector and set the cover aside.[FONT=Arial045.813]
[FONT=Arial045.813]5. Disconnect the power wire harness connector (BL/BK and W wires)[/FONT]
[FONT=Arial045.813]6. Disconnect the flapper door heater wire harness connector (if one is present).[/FONT]
[FONT=Arial045.813]7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.[/FONT]
[FONT=Arial045.813]8. Disconnect the wires from the terminals of the lamp holder.[/FONT]
[FONT=Arial045.813][FONT=Arial045.813][FONT=Arial045.813]9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.[/FONT]
[FONT=Arial045.813]10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.[/FONT]
[FONT=Arial045.813]11. Unsnap the ice guide and remove it from the ice dispenser lever.[/FONT]
[FONT=Arial045.813][FONT=Arial045.813][FONT=Arial045.813]12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.[/FONT]
[FONT=Arial045.813]13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.[/FONT]
[FONT=Arial045.813]14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.[/FONT]
[FONT=Arial045.813]15. Remove the water dispenser lever.[/FONT]
[FONT=Arial045.813]16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly[/FONT]
[FONT=Arial045.813][FONT=Arial045.813][FONT=Arial045.813]17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.[/FONT]
[FONT=Arial045.813]18. Reassemble in reverse order.[/FONT]
[FONT=Arial045.813]Good Luck,[/FONT]
[FONT=Arial045.813]:) :) :) [/FONT]
[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
Kitchenaid Refrig Repair (Refrigerator & Freezer Repair)
by Jon Williams 12/18/2007 12:29:08 PM(UTC)
