I am having problems with my Ice maker, I have taken it apart and cleaned the Tray and used the re-set button to make sure the ice is dumping..what is happening is the ice maker seems to work fine for a day or so, then when you go to get ice it is frozen up.what appears to be happening is the tray is filling up (but maybe not dumping ???) then the water overflows and freezes up in the cube collection tray then I have to dump hot water into it to melt the ice block out of it remove it ......this is difficult to explain I hope you understand The water dispenser is working fine so I assume the Valve is OK.the filter is only about 2 months old and we have soft water so it usually last 6 to 8 months HELP !!!!
