| » Ice maker only makes crushed ice-no cubes |
Model Number: ksbp25fkss00 Brand: Kitchen Aid Age: 5 - 10 years
Ice maker works fine, but only dispenses crushed thru the door--no cubes.
Pull your ice bin out and look at the opening where the brass colored rod enters. There is a solenoid (AP3132895) inside the housing that should actuate to move the bucket arm in order to dispense cubes. Stick your finger in there and see if you can get it to drop down. The solenoid may be damaged, or just frozen in place. Once it drops down and with the freezer door open, actuate the door switch with your finger, while pressing the ice lever in the dispenser. Make sure you have selected cube and crushed first. The solenoid if it is working will snap up then fall back down when you release the lever. If it doesn't, then you will need to remove the housing it is in and see if it is full of frost. The solenoid shaft must move freely in order to work properly. They will rust with time and become pitted preventing proper operation.
Brian, thank you,
Everything seems to be moving freely, no rust, no ice etc, and still no cubes. The opening on the mechanism that the rod from the ice try goes into does not move up or down. It just stays down with the door opened and the ice activated. |
| Display Modes | |
| Ice Maker Dispenses Crushed Ice But Not Ice Cubes | JoeMontovino | Refrigerator & Freezer Repair | 11 | 12-07-2009 01:51 PM |
| Ice maker will not switch from crushed ice to cubes | glassguy28 | Refrigerator & Freezer Repair | 0 | 07-19-2009 05:57 AM |
| refrigerator makes normal size ice cubes, but will only dispense crushed ice | Bob Subin | Refrigerator & Freezer Repair | 0 | 12-31-2008 05:59 AM |
| Ice maker makes normal sized ice cubes, but will only dispense crushed ice. | TekGod | Refrigerator & Freezer Repair | 1 | 12-15-2008 07:25 PM |
| Ice maker works. Won't dispense cubes or crushed ice | Derjimmer | Refrigerator & Freezer Repair | 32 | 08-11-2008 11:36 AM |
