| » Water Dispenser (Front) Fitting |
Model Number: ED22GWXFW02 Brand: Whirlpool Age: 5 - 10 years
I have to replace the water dispenser fitting, Pc. 10. I have ordered and received Part #Whirlpool 4388152. The replacement package I received contains two separate assys, one short black tube assy with a white nozzle and one long white water hose assy with a bracket on the end. My broken component, to be replaced, is the white nozzle on the end of the short black tube assy.
What is the best way to replace my broken component? Do I have to remove the black front dispenser faceplate and if so, how do I go about it? Thank you, Richard Moore 804-815-0730 Cell drifterpilot@cox.net Ads By Google Related Models |
Hi Richard,
You do not have to install everything from the kit. Replace whatever has to be replaced. You have to remove the dispenser front cover first. It can be removed by inserting a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed. Here are the break down diagrams for the Whirlpool refrigerator Model ED22GWXFW02 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Richard,
You are welcome. I'm glad you were able to fix it. Gene.
__________________
What did you do exactly? I believe I need to replace the same piece as you and have the kit in had, but I see no way to remove the piece that directs the water down into your glass. It appears to be permanently attached to the black tube.
HELP! |
How I was told that it must be replace as the whole assemb lt by whirpool tech, or ruin the insallation I went to reair line an they don't know what the nozzle, is so I return the water line from the rev tank and caped it My question is can,the nozzle tip be replace ?They said because the nozzle tip is corroded and,they said it loosing vaccum an causing the consit drip on the tray and overfilling with water I want my cold water back.. Joemasi
What is the complete model number of the refrigerator?
__________________
[quote=jmasifla;405761]How I was told that it must be replace as the whole assemb lt by whirpool tech, or ruin the insallation I went to reair line an they don't know what the nozzle, is so I return the water line from the rev tank and caped it My question is can,the nozzle tip be replace ?They said because the nozzle tip is corroded and,they said it loosing vaccum an causing the consit drip on the tray and overfilling with water I want my cold water back.. Joe masi[...masifla@msn.com
| Display Modes | |
| Kenmore Refrigerator front water dispenser not working | neustkg | Refrigerator & Freezer Repair | 13 | 08-15-2011 09:51 AM |
| No power to GE GSS front panel/water dispenser | jleigh | Refrigerator & Freezer Repair | 2 | 06-06-2010 06:03 PM |
| water leak in front of refrigerator when using water dispenser | RichardCh | Refrigerator & Freezer Repair | 0 | 08-10-2009 10:29 AM |
| How to remove front panel of water/ice dispenser | Caliche | Refrigerator & Freezer Repair | 1 | 02-23-2009 02:28 PM |
| removing cover off front of water/ice dispenser | need4help | Refrigerator & Freezer Repair | 1 | 11-02-2007 10:48 AM |
