After cleaning coils and drip tray.Noticed that water fro ice dispensor and ice melting. Freezer not freezing and food softening in freeze. The Overload/Relay Switch attached to the compressor will click, the compressor tries to start for3 to 7 seconds (no humming noise from the compresor), another click from the (Overload/Relay Switch), compressor still not humming. This process cycles about every minute 20 to35 seconds. Question: will replacing the Overload/Relay Switch fix my problem? The Overload/Relay Switch has three female that plugs into the three male compressor attached pins. Was is the Part No.for the right Overload/Relay Switch for my fridge? Do I need to replace the capacitor also that is wired to the Overload/Relay Switch?
:o KSRA25ILSS01 should be the correct model number. Their been two numbers AP3083556 and AP3885081 .:confused: Neither look like one on compressor. So wanted to know which is correct and if it would fix problem.
Order the AP3885081, comes with complete instructions.
I will order the part and install it and tell the results.
Originally Posted by: LaLobo I will order the part and install it and tell the results. I installed new parts. Turned on Refrigerator.Compressor still does not turn on. Hear the relay come on for 10 seconds and then turns off. Then wait 10 minutes and tries agian. I think I should of replace also the capacitor. I well wait for your reply. Thanks
Your run capacitor has nothing to do with starting the compressor. You have a damaged compressor, either mechanically locked up, or a bad start winding. This assumes you installed the parts correctly. An amprobe would confirm a bad compressor.
